- Hardware & Machines
- Computers and OS's
- Is there a reason to choose J1900 over newer models like J3455?
07 Apr 2018 22:37 - 07 Apr 2018 22:39 #108577
by warreng
Comparing this board: www.newegg.com/Product/Product.aspx?Item=N82E16813157497
to this board: www.newegg.com/Product/Product.aspx?Item...13-157-727-_-Product
Seems the newer/faster board is slightly cheaper (not that it matters so much). But looking through some threads here and reading about preept-RT requiring more CPU, makes me think the faster model would be a better idea. But are there any gotcha's to look out for?
Lastly, I have a case and power supply from a Gateway SX2110G-UW318 where the mobo died suddenly. This case will take a m-ITX but won't quite fit a m-ATX (has 2 PCI-e slots instead of 3). But I still have a 4G ram card from the original mobo. It's a full size dimm and I can't find any m-ITX mobos that don't take so-dimm. If I can't reuse it then, I can't reuse it. But wondering if anyone has any suggestions.
btw, I'd like to have both parallel port and Mesa options (probably end up with the 7i76e eventually).
Thanks,
Thanks,
Last edit: 07 Apr 2018 22:39 by warreng.
08 Apr 2018 14:15 #108603
Replied by PCW on topic Is there a reason to choose J1900 over newer models like J3455?
I have a J3355 and its nice except it had troubles with older dists like Wheezy so it may not
be the best host for a RTAI/Parallel port configuration
Time to create page: 0.076 seconds
