Installing rt preempt
20 May 2018 19:15 #110930
by JR1050
Installing rt preempt was created by JR1050
hello,
I am tryimg to install rt preempt(the patch ) on the rockchip 3228 based Libre renegade board. It presently has their version of ubuntu 16.04. Following the instructions from several different sites(more like trying what worked), managed to get the kernal sources unpacked, the patch unpacked and the sources patched. My next step would be select the realtime from the blue menu, but here is the issue, there is no menu!! Ive tried make menuconfig and keep getting this, it seems im missing a header file
firefly@firefly:/usr/src/linux-4.4.12$ make menuconfig
HOSTCC scripts/kconfig/mconf.o
In file included from scripts/kconfig/mconf.c:23:0:
scripts/kconfig/lxdialog/dialog.h:38:20: fatal error: curses.h: No such file or directory
compilation terminated.
scripts/Makefile.host:108: recipe for target 'scripts/kconfig/mconf.o' failed
make[1]: *** [scripts/kconfig/mconf.o] Error 1
Makefile:531: recipe for target 'menuconfig' failed
make: *** [menuconfig] Error 2
I attempted to install
apt-get install libncurses5-dev
as it seems it would make the menu, but it resulted in this
firefly@firefly:/usr/src/linux-4.4.12$ make rk3228_defconfig
HOSTCC scripts/kconfig/conf.o
scripts/kconfig/conf.c:722:1: fatal error: opening dependency file scripts/kconfig/.conf.o.d: Permission denied
scripts/Makefile.host:108: recipe for target 'scripts/kconfig/conf.o' failed
make[1]: *** [scripts/kconfig/conf.o] Error 1
Makefile:531: recipe for target 'rk3228_defconfig' failed
make: *** [rk3228_defconfig] Error 2
Ill admit, Im out of my comfort zone with this, any advice /suggestions on where to go with this?
Should I be using the firefly/rockchip kernal sources instead of the palin linux?
Thanks as always....
- InMyDarkestHour
- User is blocked
- Thank you received: 111
21 May 2018 05:34 #110948
by InMyDarkestHour
Replied by InMyDarkestHour on topic Installing rt preempt
Have you tried sudo make menuconfig ?
Time to create page: 0.111 seconds
