XFCE's Standard Dock is Suboptimal for Touchscreens
04 Jun 2018 15:42 #111606
by Clive S
I can vouch for that as I do in fact read every post from the recent topic list and just doing that involves over an hour a day.
But I have learnt a lot by doing it. Thanks to all the guys and dolls answering the questions:cheer:
Replied by Clive S on topic XFCE's Standard Dock is Suboptimal for Touchscreens
(If you don't believe me, try to read every post from the last week)
- InMyDarkestHour
- User is blocked
- Thank you received: 111
04 Jun 2018 21:03 #111621
by InMyDarkestHour
As previously stated
So.......you aren't actually using Linuxcnc on your machine (I give up) ?
Replied by InMyDarkestHour on topic XFCE's Standard Dock is Suboptimal for Touchscreens
In my CNC machine, I have old stepper motors, which use special code, which might rarely ever be needed in LinuxCNC. I realize that at some point the very code my machine runs on likely should be removed for the advancement of LinuxCNC. In the same way, I don't think that LinuxCNC should remain optimized for large 4:3 monitors.
I stand by my assertion that XFCE's standard dock is wasteful of screen area, and as a default it should be changed so it can be used better with modern monitors.
I implore those who stand against something that may help new LinuxCNC users acclimate, to try moving the icons to other command bar, shut off the dock, use LinuxCNC for a while, and then switch back.
I am just a piano player but have to ask, are you for real?
05 Jun 2018 21:58 #111707
by BrendaEM
Replied by BrendaEM on topic XFCE's Standard Dock is Suboptimal for Touchscreens
Ozzyrob, could you please recast your sentence and redo your post, so people might know what you are referring to, or with whom you are conversing with?
Time to create page: 0.099 seconds
