Beagleboard x15 and LinuxCNC
20 Jun 2018 10:39 #112615
by dom96
Beagleboard x15 and LinuxCNC was created by dom96
Hi All,
Would the BeagleBoard x15 be any good for running LinuxCNC with Ethernet based Mesa cards? I am basically looking for some very small computer with good latency and a graphics chip good enough to play 1080p videos while operating the CNC machine at the same time and not affect its performance.
Would the BeagleBoard be good enough for this or should I get something different? What latency results can I expect from this single board PC?
- InMyDarkestHour
- User is blocked
- Thank you received: 111
20 Jun 2018 11:12 #112623
by InMyDarkestHour
Replied by InMyDarkestHour on topic Beagleboard x15 and LinuxCNC
Don't play videos on the same machine you running a cnc machine with, actually don't do anything else with it whilst it controlling a machine.
Geesh the x15 is not a cheap option.
Grab a cheap PC and use the MESA kit & Linuxcnc and consider something else for watching videos. You might even be able to press a cheapish "smart tv" into service.
The following user(s) said Thank You: dom96
20 Jun 2018 11:39 #112626
by dom96
Replied by dom96 on topic Beagleboard x15 and LinuxCNC
Thanks for the advice. What I like about the x15 is the size, I wanted to have the controller PC as small as possible. Would it still be good with the latency though if not playing the videos? I dont mind paying a little extra to have the PC smaller as long as the latency is good. What alternative small PC would you recommend?
- Thank you received: 5934
20 Jun 2018 21:56 #112666
Replied by tommylight on topic Beagleboard x15 and LinuxCNC
There was a time when i was trying to get Linuxcnc to run on anything possible, even on some old pentium 2 laptops and some SBC till i thought : what is the use of that ?
Using a small computer to run a machine that is always bigger that a desktop computer is pointless ! So i use desktop computers and sometimes micro ATX motherboards from ASUS.
So far i have 1 RPI3 with added controller boards that is in use, 1 only. And with added controllers it is not small any more, add the drives and ......you get the picture.
- InMyDarkestHour
- User is blocked
20 Jun 2018 22:07 #112667
by InMyDarkestHour
Beaglebone Black and Machinekit is an option.
ATM I'm migrating from my BBB & Machinekit to an ITX board and Linuxcnc, the support via the forums for Linuxcnc is thousands of times better than Machinekit
21 Jun 2018 10:22 #112711
by dom96
Thank you. So I found out that the J3355B-ITX is a small mini ITX board that is meant to be good for linuxcnc as it offers really nice latency but it only has one ethernet port which means I would have no internet connection if the Mesa card is connected. Does anyone know about a similar mini-ITX board equally good with 2 ethernet ports?
Here is the link to the ASRock J3355B-ITX :
www.newegg.com/global/ie/Product/Product...Item=N82E16813157726
21 Jun 2018 10:35 #112712
by tecno
Replied by tecno on topic Beagleboard x15 and LinuxCNC
Why do you need to hook up your dedicated CNC PC to internet?
- InMyDarkestHour
- User is blocked
21 Jun 2018 10:51 #112713
by InMyDarkestHour
I use a second PCIe card for the interface for my mesa card, a TP-LINK TG3468 uses the same chipset, unfortunately it doesn't come with a low-profile bracket, but not an issue as I'm putting everything in a customised enclosure. I've renamed the interfaces lan0 for the network and mesa0 for the connection to the 7i92 I'm using.
There is a AsRock mini itx board on newegg with 2 ports, a bit more $$$ and doesn't come with a parallel port, nice to have as an option.
21 Jun 2018 11:58 - 21 Jun 2018 12:00 #112717
by Hakan
Replied by Hakan on topic Beagleboard x15 and LinuxCNC
I often listen to youtube while turning, it's a
Gigabyte GA-Z170N Wifi
with i3-6100, two ethernet ports and built in wifi. Internet comes via Wifi. That works fine.
I tested BBB and machinekit some years ago and unless things have changed the graphics is painfully slow and the memory is limited so CAM prepared files from F360 are often too large. It is a quite limited machine. With that pricetag I don't see any reason to use Beaglebone X15.
A month ago I installed a new milling machine and went for Gigabyte GA-J3455N which actually has two ethernet ports. But there was something wrong with the one I got, wouldn't even show bios screen, so replaced it with a ASrock Q1900-ITX . Only one ethernet port so Wifi is via USB wifi dongle. This works pretty nice but I don't run youtube on that one. Had to use isolcpuis=2,3 to get stable latency.
I use 7i76E on both linuxcnc systems by the way.
Last edit: 21 Jun 2018 12:00 by Hakan.
21 Jun 2018 12:34 #112722
by dom96
The main reason I wanted to have an internet connection on this PC was to be able to download the g-code files from the cloud and ocasionally get some work related info from google.
Time to create page: 0.083 seconds
