Minimum Old PC Requirements for LinuxCNC?
20 Jul 2018 17:15 #114595
by rpseguin
Minimum Old PC Requirements for LinuxCNC? was created by rpseguin
So, there's scads of old computers around, some with parallel ports, some without, so I'd prefer to get one of those for free and reuse it rather than having it be scrapped.
What's the minimum configuration that would be considered reasonable for running a 3+ axis CNC lathe or mill via parallel port with LinuxCNC?
Source for reasonable parallel port cards?
If parallel ports are a waste of time, please recommend some low cost 4+ axis motion controllers that would work with either LinuxCNC or Mach 3
I'd like to be able to get 300+ IPM rapids and have a C axis
20 Jul 2018 18:21 #114600
by BigJohnT
Replied by BigJohnT on topic Minimum Old PC Requirements for LinuxCNC?
Is this a stepper machine? Very old PC's might need to run an older version of LinuxCNC. Get the DVD and boot then run the latency test.
JT
JT
20 Jul 2018 18:37 #114602
by rpseguin
It’s for a machine that doesn’t exist yet except in my head. I would want to run the spindle as a C axis and each of the axes with step & direction probably. I don’t have any motion controllers, thus I am asking about parallel port control.
If there are reasonably priced 4+ axis motion controllers that would work, I am all ears.
Replied by rpseguin on topic Minimum Old PC Requirements for LinuxCNC?
JT
20 Jul 2018 18:56 - 20 Jul 2018 18:56 #114604
by BigJohnT
Last edit: 20 Jul 2018 18:56 by BigJohnT.
20 Jul 2018 18:58 #114605
by rpseguin
Well, I’m thinking 3+ horsepower digital AC/brushless servo for the C/spindle
A stepper driven C axis?
The Mesa 7i96 is a very cost effective stepper card.
JT
20 Jul 2018 19:09 #114607
by rpseguin
Thanks!
That is quite reasonable!
Doesn’t look like Mach supports it, but that’s not a necessity.
Any MPG recommendations?
Thanks!
JT
Thanks!
Thanks!
26 Jul 2018 12:30 #114871
By all means start with the p-port. It's cheap and actually works fairly well. Any PC that can work with LinuxCNC and the parport will also work with the supported motion control cards too. (And the Pico cards need the parport, they use it in EPP mode as a data bus, as do some Mesa cards).
I configured a stepper-lathe (old Denford ORAC) at the weekend and the p-port was perfectly capable of driving the machine right up to the (rather low) hardware speed limits.
Replied by andypugh on topic Minimum Old PC Requirements for LinuxCNC?
