PCIe Double Parallel Port Card.
- Topic Author
- Online
- Thank you received: 1369
02 Aug 2018 13:42 #115406
PCIe Double Parallel Port Card. was created by Todd Zuercher
I know that a lot of people have had some trouble getting PCIe parallel port cards to work.
I just wanted to report a card that I believe does work. At least for ordinary IO not sure about as an EPP bus as I don't have any of that kind of hardware to test with.
The card is a SIIG DP CyberParallel Dual PCIe card, and uses a MosChip 9865 chip.
www.amazon.com/SIIG-DP-CyberParallel-PCI...011-S3/dp/B008C4HPUO
Not the cheapest card out there but there aren't a lot of choices if you need a PCIe card with 2 ports.
I am still building my config, and connecting to the machine, so it isn't fully tested yet, but I can see outputs and inputs working.
- Topic Author
- Online
29 Aug 2018 14:51 #116773
Replied by Todd Zuercher on topic PCIe Double Parallel Port Card.
Perhaps I spoke too soon. It seems I am having trouble using the control pin outputs (Pins 1,14,16,17). This only is a problem in the usual out and in modes. The card surprisingly works perfectly well in X mode using those pins as inputs. I am guessing it also does not work for EPP.
Time to create page: 0.061 seconds
