Recommended hardware
Is there any commercial small form factor PC tested and recommended for emc2?
I saw somebody was trying Dell OptiPlex models.
What keyboards and touchpads for industrial use (very dusty) work fine?
What SSD's are recommended? (Samsung Pro 850 or similar?)
The PCs don't need to be new models, just available ones!
Also:
What are the additional cards recommended? (Parallel cards, Mesa, etc.?)
Is touchscreen support available and working?
I came to see if Raspberry has good reviews, but I see that PC's are still the better option.
I have 3 emc2 systems (already 5 years old) running on machines with Ubuntu 8.04, and I want to update the hardware.
Thanks in advance!
- Thank you received: 5942
If you can also find older Dell keyboards they are also very good.
I also use strictly Mesa cards, had over 20 of them installed and working without a single issue, ever.
Use the RTAI kernel version of Linuxcnc, most probably you are already using that one.
Any type of SSD will work fine, i use Samsung, Intel, and Adata ( i have an Adata Pro something that does 560MB/s writes). Hard drives also work nicely but they tend to raise the latency a bit.
It is very important to disable Intel speedstep and C0 sleep modes in bios.
I know that the J1900 based Gigabyte Brix is also ok for Ethernet. Probably newer mini PCs are ok also but i don't have personal experience with them.
I can confirm the J1900 and N3160 Gigabyte Brix PC's work fine. I have a J1900 on my LinuxCNC machine and writing this on a N3160. Just you can't use the internal wifi card. You need a USB wifi dongle.
IS this one of the units you recommended:
articulo.mercadolibre.com.mx/MLM-6001432...42ghz-_JM?quantity=1
As I see, there is has a mini PCI Express slot. I would have to use it for a parallel card. (What models would fit and work?)
Personally, If I was to run a parallel port, I'd look at the other recommendations.
Hmm never heard about this one. How much lower is the speed when AMT is enabled on ethernet?if you disable the Intel spyware (AMT).
Pcw, concider to design a ethercat board. That would be nice, in manhatten style has my prefix...
From what i see now is that it is the fastest protocol ever. If mesa spend some time in this protocol and build some hardware
around this, they would have the fastest i/o product on earth. I bet for sure.
is about 1 KHz. This increases to about 4 KHz with AMT disabled
Not terribly interested in Ethercat since AFAIK its not possible to make a hardware slave device with open source firmware.
Reviewing the Slave (SOEM) License at open Ethercat Society, I can't see there are any restrictions preventing using it for opensource projects. In fact its specifically allowed.
github.com/OpenEtherCATsociety/SOES/blob/master/LICENSE
Its just that if you make a work based on this software, you don't have to publish the derived wotk as open source
SOES is free software; you can redistribute it and/or modify it under
the terms of the GNU General Public License version 2 as published by the Free
Software Foundation.
SOES is distributed in the hope that it will be useful, but WITHOUT ANY
WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
As a special exception, if other files instantiate templates or use macros
or inline functions from this file, or you compile this file and link it
with other works to produce a work based on this file, this file does not
by itself cause the resulting work to be covered by the GNU General Public
License. However the source code for this file must still be made available
in accordance with section (3) of the GNU General Public License.
This exception does not invalidate any other reasons why a work based on
this file might be covered by the GNU General Public License.
To me this is designed to protect companies like Mesa from being forced to publish their IP as open source unless they want to.
It seems the default position of the Open Source movement is that becasue there is a restriction in the license it can't be included into the LinuxCNC core but in my view and I quote "This exception does not invalidate any other reasons why a work based on
this file might be covered by the GNU General Public License". In other words if you want to GPL a derived work, you can.
