computer for LinuxCNC
- emmamillathompson
02 Jan 2019 08:47 #123311
by emmamillathompson
computer for LinuxCNC was created by emmamillathompson
Anyone successfully using LinuxCNC on a single-board computer?
Looking to run LinuxCNC with a Mesa card (probably a 7i92) For packaging reasons, i need a single-board computer (not enough cabinet space for a full-size PC)
Looking for names/models of single-board computers that others have used successfully
02 Jan 2019 14:07 #123330
by trilobyte
Replied by trilobyte on topic computer for LinuxCNC
i use a up squared with celeron N3350 processor:
up-shop.org/home/270-up-squared.html#/96...4gb_memory_32gb_emmc
up-shop.org/up-peripherals/248-new-up-sq...-mounting-plate.html
it works fine with the 7i76e.
i've the system running with the r13 image: www.linuxcnc.org/testing-stretch-rtpreempt/
Peter
Peter
03 Jan 2019 05:45 #123389
by wicki
I made a test-installation with linuxcnc on as rapsberry-PI 3 - two years ago.
3 axes with a standard TB6550-china-board via GPIO.
it works:
erste.de/cerec1.avi
Replied by wicki on topic computer for LinuxCNC
it works:
erste.de/cerec1.avi
- ihavenofish
- Thank you received: 84
10 Jan 2019 02:02 #123884
by ihavenofish
Replied by ihavenofish on topic computer for LinuxCNC
Does the up squared "just work" like a normal computer when installing linuxcnc? Im looking at aaeons pico itx boards as well, and It turns out other than the shape, they are effectively the same thing for the same price - but the up squared is much easier to get in small volume and short notice (I just need 5).
thanks!
thanks!
10 Jan 2019 08:59 #123890
by trilobyte
jep the up squared is a little "normal computer".
the up board with Z8350 didn't work, but the up squared with n3350 (dual core celeron) works well with the debian stretch testing image.
peter
peter
- ihavenofish
10 Jan 2019 11:34 #123894
by ihavenofish
Awesome, thanks! I'll order one up friday.
- ihavenofish
10 Jan 2019 12:02 #123895
by ihavenofish
do you have access to the hat connector and fpga within Linux? I want to run some dotstar leds (spi) as a "alarm beacon" and if I don't have to use a secondary mcu that would be nice.
12 Jan 2019 14:24 #124032
by trilobyte
no i do not use this stuff!
i installed this linux image:
peter
peter
- Thank you received: 6006
01 Jun 2022 10:57 #244361
Replied by tommylight on topic computer for LinuxCNC
spammer booted.
Time to create page: 0.468 seconds
