Lilliput monitors resolution
18 Mar 2019 13:13 #128893
by RotarySMP
Lilliput monitors resolution was created by RotarySMP
I have been thinking about setting up a control for my lathe. Rod's posts have put me on to the gigabyte Brix's as a great space saving solution for the PC. He also recommends the Lilliput touch screens in this thread.
forum.linuxcnc.org/38-general-linuxcnc-q...ommercial-cnc#123656
I went looking on the Lilliput website, and their desciption of moniotor resolution is not very clear.
Compatible with full 1080 HDMI signals
The OF1046/C/T is designed to accept full HDMI signal, allowing you to create custom multimedia stations in smaller form factors than ever before
vrs
Native Resolution 800×600 (native)
Since Gmoccpy needs at least 1024x768, will it display correctly on one of these lilliput monitors, or does the monitor just oversample signals but display them at 800x600?
Mark
vrs
Mark
18 Mar 2019 18:03 #128914
by Leon82
Replied by Leon82 on topic Lilliput monitors resolution
It may chip off the buttons on the bottom. I went from a 19" insignia TV to a planar 22" monitor and it is fine on the 22 but chopped on the 19
- Thank you received: 6006
18 Mar 2019 21:24 #128921
Replied by tommylight on topic Lilliput monitors resolution
I do have a 7" monitor that does that, namely the upscaling and it is a disaster to watch. It can do 1024x768 but the native resolution is 640x480. It is collecting dust in the workshop.
22 Mar 2019 13:38 #129256
Replied by rodw on topic Lilliput monitors resolution
I don't think the Lilliputs would work as they upscale from 800x600. I've got a 7" Xenarc with that resolution but never run it in 1024 x 768 as it was pretty awful.. It seems that Xenarc now have a 1024x600 in 7". *" and 10.1" which might be worth a look.
22 Mar 2019 14:06 #129257
by RotarySMP
Replied by RotarySMP on topic Lilliput monitors resolution
Thanks for confirming that Rod.
I wonder if the Sunfounder 10.1" screens play well with LinuxCNC?
www.sunfounder.com/10-1-touch-screen.html
They claim linux support, and have a separate usb connection for the touch function, but I did some searching and couldn't find any clear evidence of them either working or not working completely under linuxCNC.
Mark
Mark
- InMyDarkestHour
- User is blocked
- Thank you received: 111
22 Mar 2019 18:34 #129271
by InMyDarkestHour
Replied by InMyDarkestHour on topic Lilliput monitors resolution
Considering it is claimed to work with Raspian on the Pi...... I would imagine it should work on other Debian based distros.
Also along with Ubuntu.
22 Mar 2019 23:50 #129311
The touchscreen s really just a USB mouse as far as the system is concerned. When I added one to my machine, it just came up in Mint with no config changes at all. Maybe look for a 15" monitor designed for POS systems
23 Mar 2019 16:51 - 23 Mar 2019 16:52 #129379
by RotarySMP
I used a 17" monitor on my mill, and it seems unnecessarily large for gmoccapy. For my lathe I have much less space than for my mill, and think I'll try the 10". Also a glass covered capactive screen should be easier to keep clean then the plastic cover resistive screen I have on the mill.
Mark
Mark
Last edit: 23 Mar 2019 16:52 by RotarySMP.
25 Mar 2019 14:52 #129577
by pl7i92
Replied by pl7i92 on topic Lilliput monitors resolution
the rapberry compatible ones at 8" are quite good at plasma as only to be controled no programm action
- InMyDarkestHour
- User is blocked
26 Mar 2019 13:05 #129684
by InMyDarkestHour
Not connected with waveshare (have bought some of their arm dev boards) but came across these:
1280X800 resolution
www.waveshare.com/product/10.1inch-hdmi-...-case-for-europe.htm
1280X800 resolution
Time to create page: 0.094 seconds
