raspberry pi 3 model b+ support realtime
- mahmoudgad
19 Mar 2019 14:21 #128972
by mahmoudgad
raspberry pi 3 model b+ support realtime was created by mahmoudgad
Hello everyone,
I would like to ask some questions about rasraspberry pi 3 model b+
- raspberry pi 3 model b+ is found any problem with Latency or real-time
- if the raspberry pi not good solution for providing real-time app what the alternative?
20 Mar 2019 13:30 #129055
by pl7i92
Replied by pl7i92 on topic raspberry pi 3 model b+ support realtime
raspberry comunication is not that good
only up to 500mm/min at max 5000steps per decond
use a ITX like J1800/1900
M525D
better then all if a real mashine is on the system
M525D
The following user(s) said Thank You: mahmoudgad
20 Mar 2019 13:46 - 20 Mar 2019 13:48 #129065
It has usable realtime performance, but there isn't a very good selection of interface hardware.
The GPIO pins can be used, but encoder counting and step generation have to be done in software (like a parallel port system)
There is a driver (hal_gpio) but I don't see it in the LinuxCNC source tree, just in the Wiki.
There is some oddly laid-out info here. wiki.linuxcnc.org/cgi-bin/wiki.pl?RPi3BPreemptRT
The other option is to use the SPI bus and the Mesa 7i90 . Support for that is included in LinuxCNC
Replied by andypugh on topic raspberry pi 3 model b+ support realtime
Last edit: 20 Mar 2019 13:48 by andypugh.
- Thank you received: 5932
20 Mar 2019 20:38 #129109
Replied by tommylight on topic raspberry pi 3 model b+ support realtime
A normal 3 to 10 year old PC with parallel port will do just fine.
20 Mar 2019 20:43 #129110
Also the 7C80 and 7C81 which are a mechanical match to the RPI
(and should be available towards the end of April)
Replied by PCW on topic raspberry pi 3 model b+ support realtime
02 May 2019 18:39 #132554
by stevedw
Replied by stevedw on topic raspberry pi 3 model b+ support realtime
Any update on these(7C80)? I'm not yet seeing them in the various stores selling Mesa boards.
27 Jun 2019 19:41 #138022
by AgentWD40
Replied by AgentWD40 on topic raspberry pi 3 model b+ support realtime
*bump* for the previous question. I see the 7c81 is in the store, but not the 7c80.
Can the rpi run the ethernet mesa cards like the 7i76e and 7i96?
Finally and most importantly, thoughts on the new rpi 4 with linuxcnc/mesa?
27 Jun 2019 19:47 - 27 Jun 2019 19:47 #138024
The Pi3 does not work with Ethernet Mesa cards as the ethernet is on the USB bus.
But: It seems that this is not the case with the Pi4. So there is more chance of that working.
The raspian_stretch_full.gz file here is supposedly a pre-installed LinuxCNC image for the Pi3B+. I haven't tried it myself (I was going to do the same thing, but got beaten to it)
geneslinuxbox.net:6309/gene/Genes-os9-st...ebian-stretch-armhf/
Last edit: 27 Jun 2019 19:47 by andypugh.
The following user(s) said Thank You: AgentWD40
03 Aug 2019 22:32 - 03 Aug 2019 23:42 #141302
by spma
Replied by spma on topic raspberry pi 3 model b+ support realtime
Hi everyone!
I just want to leave my experience here because I've been able to successfully use an Pi3b+ with a Mesa 7i92 + 7i77 + 7i84 boards.
It was implemented on a Pinacho Lathe with servo motors and controls everything (including PLC logic) with a servo_thread of 2.5ms.
It controls 2 axis + Spindle + 2 MPG hand weels + Spindle Gearbox (3 gears) + ATC Turret + control panel with basic buttons and analog signals to control the feed bars on Gmoccapy.
(LinuxCNC v2.7.14)
Regarding the Pi4 stuff, I'm currently building a PREEMPT-RT kernel on mine to start testing it out, so I'll post updates about it in the Pi4 topic.
(LinuxCNC v2.7.14)
Last edit: 03 Aug 2019 23:42 by spma.
05 Aug 2019 02:35 #141390
by Bari
Replied by Bari on topic raspberry pi 3 model b+ support realtime
Rpi4 already working with LCNC:
forum.linuxcnc.org/18-computer/36879-raspberry-pi-4?start=0
Two mesa boards already tested and working over SPI and Ethernet.
