- Hardware & Machines
- Computers and OS's
- Recommendations for a PCIe Parallel card available in the Uk?
- YanikTheYak
21 Mar 2019 18:21 #129209
by YanikTheYak
Hi
I've seen this Parallel card on Amazon and wondered if anyone knows if it works?
www.amazon.co.uk/KALEA-INFORMATIQUE-Expr...uerres/dp/B01M10PHLP
If not, any other recommendations?
Just getting started
Ian
Ian
21 Mar 2019 23:55 #129233
Replied by andypugh on topic Recommendations for a PCIe Parallel card available in the Uk?
I was going to suggest this instead:
eusurplus.com/index.php?route=product/pr...63_291&product_id=54
(Much more than just a parallel port)
But they are out of stock.
I bought a bunch of cards a while back to try to answer this question,
forum.linuxcnc.org/38-general-linuxcnc-q...sic-questions#102070
This one looks likely, if you don't want or need EPP.
www.amazon.co.uk/KALEA-INFORMATIQUE-Cont...ds=pcie+db25+moschip
Avoid any with the tine WCH chip, those need to load a driver to the cad at boot time. and don't work with LinuxCNC.
The following user(s) said Thank You: YanikTheYak
- Thank you received: 5944
22 Mar 2019 02:02 #129238
Replied by tommylight on topic Recommendations for a PCIe Parallel card available in the Uk?
I have used several PCI card with MosChip (NetMos), never had problems with them, and they do work on different modes, In, Out or X.
See if you can find any PCIe with that chip, they should work with Linuxcnc.
- YanikTheYak
22 Mar 2019 09:26 #129246
by YanikTheYak
Replied by YanikTheYak on topic Recommendations for a PCIe Parallel card available in the Uk?
Thanks for your speedy help!!
I just ordered one of these, based on the Oxford chips.
rover.ebay.com/rover/0/0/0?mpre=https%3A...2Fitm%2F272875358222
Will let people know if I get it to work.
Ian
Ian
