Mini-itx motherboard with PCI slot
28 Mar 2019 21:28 #129859
by ississ
Mini-itx motherboard with PCI slot was created by ississ
Hi
Does anyone have a suggestion for a known working mini-itx motherboard for linuxcnc use with a PCI slot ?
I'm planning to replace the old P4 controller pc and it would be good to reuse the mesa 5i25 card, so the pci slot requirement.
Gigabyte GA-J3455N-D3H was mentioned in some of the posts, I believe it requires the newer kernel (rt-preempt version).
Or maybe a GA-J1800N-D2PH ?
Something else ?
Something else ?
- Thank you received: 5945
29 Mar 2019 01:48 #129876
Replied by tommylight on topic Mini-itx motherboard with PCI slot
mini-itx.com
go to shop
left side menu choose what you want.
go to shop
29 Mar 2019 07:43 #129888
by pl7i92
Replied by pl7i92 on topic Mini-itx motherboard with PCI slot
lots of stuff also in your near FABLAB
or PC-Store on the Backwall
or under the Table
or under the Table
29 Mar 2019 09:47 #129891
by ississ
Replied by ississ on topic Mini-itx motherboard with PCI slot
Yes, I know how to search for boards based on needed properties.
But, for example @mini-itx.com limiting the boards with pci slot gives 3 boards:
Jetway JNC9KDL-2550
Jetway JNF9D-2550
Jetways are quite old so the only real possibility is Gigabyte (on that shop).
Someone mentioned the board on some posts but the final results were missing, so it's not clear if this board will work correctly or not.
There is also mentions about older J1800 boards but no exact models.
Just thought that someone may have tested or is running linuxcnc on similar board and can suggest some model...
Jetway JNC9KDL-2550
Jetway JNF9D-2550
29 Mar 2019 16:59 #129909
Replied by andypugh on topic Mini-itx motherboard with PCI slot
Not 100% helpful but...
I had a GA-J1800-D2P and could not install Linux on it (UEFI, I think). Apparently later revisions were better, but the one I had is probably still in a box somewhere.
I can't say whether the same problem will apply to the GA-J3455N you mentioned.
My Lathe is running a Jetway JNF9C-2800 and that has been good I accidentally did a latency test last night (badly calibrated touchscreen and it was < 3000nS.
www.mini-box.com/Gigabyte-J1900N-D3V might be an option.
Time to create page: 0.152 seconds
