are SMB network file shares supported?
18 Apr 2019 19:27 #131177
by travis036
Replied by travis036 on topic are SMB network file shares supported?
ok, thanks. i will begin saving for a wireless PTP setup.
~Travis
~Travis
20 Apr 2019 22:57 #131337
Replied by andypugh on topic are SMB network file shares supported?
My machines are set up with Samba and Avahi.
So if the machines are turned on they appear in my Mac finder, and I save G-code files direct from the CAD/CAM to the nc_files folder on the machines.
Thos also works from Inventor running in a Windows VM on the Mac, or from the LinuxCNC VMs.
So, yes, Samba works well, and it works even better with Avahi set up.
20 Apr 2019 22:59 #131338
Oh, and the network link to my workshop is via Homeplug
en.wikipedia.org/wiki/HomePlug
24 May 2019 18:23 #134838
by ississ
Replied by ississ on topic are SMB network file shares supported?
I also use samba on all linuxcnc machines to be able to copy nc files from my windows workstation.
Samba setup is so that all copied files are converted to lowercase so that axis finds them if windows creates upper case file names.
Wake on lan and vnc server are also very handy, there is no need to go to the garage to test things...
My garage is a separate building, the cable length is below 50m and there is a simple HP 1G router on both ends.
