Computer for Mesa 7i76E
I'm building a plasma table based on the v1engineering LowRider2 router table. It will run nema 17s and a hypertherm 45xp. I've already ordered (maybe prematurely) a 7i76E and a THCAD-300. I figured on the ethernet version because I thought it would be more flexible and I've read on this forum it is at least slightly less dependent on computer jitter. I have an old computer, intel Core i3 I think, that I had intended to use for this project. I booted the Live USB Stretch development version amd64-r13 and the max jitter was around 150k. It hovered around 20k but spiked when I was playing with the wifi...
Question #1. I realize Core i3 is intel, not AMD, but that's the correct version for 64 bit, right? I *kinda* remember reading I needed 64 bit, please correct me if I'm wrong.
Question #2. Does this Live USB itself use the preempt kernel?
Question #3. If I have to buy a new (to me) computer I'd prefer a mini pc. I've seen recommendations from a few years ago for j1900. Can anyone provide updated recommendations for proven hardware and what kind of jitter I should expect?
Question #4. What kind of jitter is acceptable to run a plasma table with nema 17s anyway?
Question #5. I did read in the wiki docs about interpreting the jitter results. I get the impression that higher step speeds require lower jitter and vise versa (hence question 4), am I off base here?
Question #6. Kinda switching topics here but can anyone recommend stepper drivers?
- InMyDarkestHour
- User is blocked
- Thank you received: 111
Since that all you got from my trying to help ya. I thought I edit to suit your interpretation.
Hmm. Perhaps I had a misunderstanding of my situation. So then I take it the 7i76e generates the steps/direction? Is linuxcnc just gcode sender at this point?Question #5: This is really only applicable to software generated step/direction (within certain limits)
Sorry, I promise I've been actively researching tons of different questions all day. The last thing I want is [edit] for anyone else to think I'm being lazy and not trying first to figure this stuff out on my own before bothering you all with questions.Searching the forum will yield some good topics relating to jitter & Mesa Cards.
- InMyDarkestHour
- User is blocked
RTFM
Sorry. You've misunderstood what I meant. That wasn't directed at you and I'm not unappreciative. I was just saying that I do try to look up my answers before bothering others with my questions.
You can use 32 or 64 bit but I would choose 64Beginner here diving in the deep end.
YesQuestion #2. Does this Live USB itself use the preempt kernel?
Most Mini PCs should be OK, just don t choose the lowest performance versionsQuestion #3. If I have to buy a new (to me) computer I'd prefer a mini pc. I've seen recommendations from a few years ago for j1900. Can anyone provide updated recommendations for proven hardware and what kind of jitter I should expect?
As long as the servo thread can run at 1 KHz you are OK even a few 100 usec jitter is OK in some casesQuestion #4. What kind of jitter is acceptable to run a plasma table with nema 17s anyway?
but NEMA17, Thats pretty darn small for a plasma table...
If you have a 7I76E the step rate is independent of the host jitter, basically LinuxCNC tells theQuestion #5. I did read in the wiki docs about interpreting the jitter results. I get the impression that higher step speeds require lower jitter and vise versa (hence question 4), am I off base here?
7I76e how fast to step 1000 times a second but the hardware generates the actual steps
(up to 10MHz on a 7I76E )
I hear you. All I can say is it has been done before! We'll see how it goes. They've been proven to be adequate for this machine design as a router table. The gantry is very light weight compared to most that I've seen anyway.. not that I've seen a lot.
The design is the lowrider2 at v1engineering dot com if you're curious.
- Thank you received: 5945
Important is to have a light gantry but firm enough so it does not flex when moving. That flex will show on cuts, and it never looks good.
