Appreciate some Thoughts on latency results
28 May 2019 21:34 #135200
Replied by rodw on topic Appreciate some Thoughts on latency results
When you say you ran the machine it was a real machine, not a sim? Sims often trigger a latency fault for me but never on the real hardware.
28 May 2019 22:08 #135207
by bally123
Replied by bally123 on topic Appreciate some Thoughts on latency results
Yep on a real machine - (cutting metal... )
I was surprised to see the error as everyone seemed confident in my numbers, so I restarted the session and continued to work for a while and it didn't reoccur, but I'm sure it would have reoccurred sooner or later...
Hopefully the SMI fix did the trick....
The following user(s) said Thank You: Mike_Eitel
04 Jun 2019 17:17 #135847
by bally123
Ok after several days the performance is good. I have seen one more occurance of the real time error, it's occurred before I start maching and seems to have no impact on machine performance. Latency numbers still well within requirement for mesa card.
Might try a graphics card at some point but for now I'm just going to roll with it until I get my back up pc built
- Thank you received: 5947
22 Nov 2022 02:14 #257287
Replied by tommylight on topic Appreciate some Thoughts on latency results
Spammer booted, he came back and added links.
22 Nov 2022 04:36 - 22 Nov 2022 04:59 #257299
by NTULINUX
Replied by NTULINUX on topic Appreciate some Thoughts on latency results
Just FYI,
I also have this repo:
github.com/NTULINUX/smi-killer
Disables SMI on Intel chipsets using standalone module, ported from RTAI:
Default value passed is 0x1 but can be controlled via ./setsmi hal_smi_masked_bits=<variable here> (no <>
Script:
github.com/NTULINUX/smi-killer/blob/master/setsmi
I also have 5.4 RTAI kernel debs for Bullseye here:
github.com/NTULINUX/RTAI/releases/tag/v5.3.3-delta
Some boards preform better with PREEMPT_RT, others have lower latency with RTAI.
In either case, please refer to this document for a list of problematic BIOS settings:
github.com/NTULINUX/RTAI/blob/for-next/README.BIOS
Using this PREEMPT_RT kernel config btw, I had latency under 1 microsecond (yes, one) with my NIC disabled in BIOS, no background tasks:
github.com/NTULINUX/gentoo_backup/blob/m...fig-6.0.0-rc1-rt2-RT
Will only boot as-is on AMD platforms with AHCI or NVMe block devices (XFS and EXT4) Does not support SystemD either (i.e. will not work with Debian)
Script:
Last edit: 22 Nov 2022 04:59 by NTULINUX. Reason: Provided heavily tuned PREEMPT_RT kernel config
Time to create page: 0.214 seconds
