Raspberry Pi 4
27 Jun 2019 21:32 #138034
by tjones
Raspberry Pi 4 was created by tjones
Hi All,
It looks like the new raspberry pi 4 fix's a lot of problems I have read about for using one for linuxcnc. Mainly the addition of real time ethernet. A few questions...
1. Will the raspberry pi 4 now we a suitable choice for connecting a 7i76E or 7i92?
2. Mesa looks to have a 7C80 in development specifically for the raspberry pi, is that board going to be available anytime soon? Does this new raspberry pi effect the development?
27 Jun 2019 21:47 - 27 Jun 2019 21:51 #138036
Replied by PCW on topic Raspberry Pi 4
1. It should but Ethernet performance is not known yet.
2. The RPI4 should just work with the 7C80/7C81 assuming its
SOC SPI interface is the same as the RPI3
The 7C81 _is_ available. the 7C80 still needs its inmux firmware
module support added to the hostmot2 driver
Last edit: 27 Jun 2019 21:51 by PCW.
07 Jul 2019 17:48 #138806
by Hakan
Replied by Hakan on topic Raspberry Pi 4
Made a quick and dirty test with 7i76E on the RPI4 4GB. It works, yes.
Can jog and run axis, didn't test more than that.
Got sveral messages that main loop took up to 0.25 seconds.
So I guess it doesn't work (so well) after all.
- Thank you received: 5946
07 Jul 2019 18:01 #138810
Replied by tommylight on topic Raspberry Pi 4
There are some things that can be tuned, but you should leave it running some gcode for at least an hour to see if it drops the connection to 7i76E.
If it does not drop it, there's still hope.
07 Jul 2019 18:02 #138811
by Hakan
I seem not to have RT preempt patches, only the PREEMPT.
I'll go hunting for that.
07 Jul 2019 18:15 #138815
Wait....
geneslinuxbox.net:6309/gene/Genes-os9-st...ebian-stretch-armhf/
But it is for the 3b, so might not work.
Thanks to Andy for the link.
Did not have time nor a microsd card to test that image yet.
07 Jul 2019 18:17 #138816
If you start LinuxCnc from a terminal, do you see
Running POSIX realtime
Or does it say non realtime ?
07 Jul 2019 19:01 - 07 Jul 2019 19:38 #138818
by Hakan
I am rather sure it said POSIX non realtime. This one sayswhile my "production" machine says
Not a very good test I am afraid. I'll start googling later in the evening.
Edit: There are actually brances with rt patches at github.com/raspberrypi/linux, called rpi-4.19.y-rt, I am using rpi-4.19.y. I will compile the rt version and give it a go.
Linux raspberrypi 4.19.57-v7l+ #2 SMP PREEMPT Sun Jul 7 12:17:55 CEST 2019 armv7l GNU/Linux
Linux zx45 4.9.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.144-3.1 (2019-02-19) x86_64 GNU/Linux
Last edit: 07 Jul 2019 19:38 by Hakan. Reason: Found the RT kernel
08 Jul 2019 16:33 #138874
by Hakan
Well, the route with "rpi-4.19.y-rt" didn't work. What works is to start with the "rpi-4.19.y" branch and apply the usual rt patches.
I now got this
and a latency_histogram that looks like this, after some random surfing on the net.
I will have to wait until tomorrow with actual test. I am pretty sure it will run (somewhat).
And to newbynobi, you have a line "import vte" in gmoccapy line 39, is that actually used? "buster" doesn't have a suitable package python-vte.
I now got this
Linux raspberrypi 4.19.57-rt22-v7l+ #5 SMP PREEMPT RT Mon Jul 8 17:42:16 CEST 2019 armv7l GNU/Linux
08 Jul 2019 16:39 #138875
A servo thread only plot would be interesting
Time to create page: 0.375 seconds
