Raspberry Pi 4
15 Jul 2019 17:39 - 15 Jul 2019 20:54 #139473
Replied by PCW on topic Raspberry Pi 4
Last edit: 15 Jul 2019 20:54 by PCW.
The following user(s) said Thank You: seuchato, tommylight
15 Jul 2019 21:22 - 16 Jul 2019 04:13 #139504
by Hakan
Replied by Hakan on topic Raspberry Pi 4
No.
Well now I have. And it made all the difference in the world.
The following is with wlan0 disabled. Leaving wlan0 up and surfing at the same time
has a huge impact on the latency numbers.Surfing brings the max latency numbers
up a factor 5, around +- 100 us.
I can try some more tomorrow, it's getting late here.
Last edit: 16 Jul 2019 04:13 by Hakan. Reason: Better graph and also with/without wlan0
17 Jul 2019 14:09 #139695
by Hakan
I have tried some, but not yet been able to get a step going. I use the 7i76E mesa card via the ethernet port.
It is possible to get it going to the point where gmoccapy is displayed and reacts to Machine On/Off.
The 7i76E displays all the inputs and outputs as it scrolls by during startup.
But when I try to jog, there is a core dump by rtapi_app. No steps are taken.
I have noticed that "iptables -N hm2-eth-rules-output2 fails with "iptables: Operation not supported"
Obviously iptables is gone, say hello to nftables. OrThat helps for those messages.
Still, when I jog the tiniest distance I getand then there is no reaction.
sudo update-alternatives --set iptables /usr/sbin/iptables-legacy
rtapi_app: caught signal 11 - dumping core
17 Jul 2019 14:21 #139699
Replied by andypugh on topic Raspberry Pi 4
I guess you are building from source? Can you try this:
github.com/LinuxCNC/linuxcnc/blob/master/docs/rtfaults.txt
This will tell us where, and in which file, the core dump is happening.
18 Jul 2019 10:49 #139774
by Hakan
I am unable to find that line in dmesg. I have never got any messages from linuxcnc in the system log file.
It is the rtapi_app that crashes. I have looked at it with strace and the last system command is "accept"
then crash. Intended to attach to rtapi_app with gdb, it should take me to the failing part upon crash.
But not succesful
But not succesful
18 Jul 2019 11:10 #139779
gdb-debugging the realtime layer is tricky. It might be possible with preempt-rt but it is basically impossible with RTAI.
Did you make the makefile changes and recompile LinuxCNC? You won't see the ip without that.
I have only ever used that approach with RTAI, it is possible that is does not work with preempt-rt as the LinuxCNC modules are not kernel modules.
18 Jul 2019 11:28 #139782
Another question: You said that you compiled the preempt-rt kernel? I did the same last night (4.19.58) and whilst it boots I seem to have lost the WiFi and Bluetooth drivers. Did you have this problem? Did you find a solution?
- Thank you received: 5983
18 Jul 2019 12:05 #139790
Replied by tommylight on topic Raspberry Pi 4
RPI3 with realtime kernel looses connectivity also, eth works.
18 Jul 2019 12:11 #139791
Is that with a self-compiled kernel, or a third-party released one?
18 Jul 2019 13:05 #139798
With both, but i do not know the version i compiled then, i can get the verion i have now as it is the machinekit image, 2 years old.
Time to create page: 0.172 seconds
