- Hardware & Machines
- Computers and OS's
- Change resolution with xrandr works, but cant input in lightdm (wheezy) ?
30 Sep 2019 19:15 - 01 Oct 2019 19:39 #146748
by tom-rock
Change resolution with xrandr works, but cant input in lightdm (wheezy) ? SOLVED was created by tom-rock
Hi all,
I am using Debian wheezy (parallel port...) and because I have a switch box it doesen´t detect the monitor and I cant get the screen resolution I want (1280x1024).
So I used the xrandr commands to change the resolution manually.
xrandr --newmode "1280x1024_60.00" 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync
xrandr --addmode VGA1 1280x1024_60.00
xrandr --output VGA1 --mode 1280x1024_60.00
When I type the commands individually in the terminal everything works and I get the resolution.
But now I want to set the resolution automatically and tried to input it in the lightdm.conf at:
display-setup-script=/home/tom-rock/customres.sh
where customres.sh was made with the commands above and gave the rights to execute (-x).
But it doesn´t work and even no gui started.
Does someone know what I am doing wrong or is it easieer to execute the above command via autostart (as a script with shebang ??)
about what I have no idea.
I would be very happy if someone could help me.
Thanks for your interest and help.
Ralf
Ralf
Last edit: 01 Oct 2019 19:39 by tom-rock.
01 Oct 2019 18:41 #146817
by tom-rock
Replied by tom-rock on topic Change resolution with xrandr works, but cant input in lightdm (wheezy) ?
Now I made the script executable with the shebang
#!/bin/bash
and I can start the script with ./customres.sh and it changes the resolution properly.
No I want to run the sript every new boot.
First I tried cron:
sudo crontab -e
and then edit : @reboot sh /home/user/customres.sh
but it does not work.
Then I tried to add it into rc.local with
but it also did nothing.
I would be very happy if someone has an idea??
Thanks and best wishes
Ralf
#!/bin/bash
First I tried cron:
sudo crontab -e
Ralf
01 Oct 2019 19:39 #146822
by tom-rock
the solution is so simple:
I just put with the gui my script in system/session into the autostart list.
With just a few mouseclicks everything is fine...
Ralf
Ralf
03 Oct 2019 04:59 #146947
Replied by andypugh on topic Change resolution with xrandr works, but cant input in lightdm (wheezy) ?
Glad you got it working. I was about to suggest creating an Xorg.conf file and doing it the old-fashioned way (which is the only way I have ever figured out how to do it)
Time to create page: 0.076 seconds
