Gigabyte G41 motherboard
- Dinuka_Shehan
- Topic Author
- Thank you received: 26
16 Oct 2019 03:30 #147965
by Dinuka_Shehan
Gigabyte G41 motherboard was created by Dinuka_Shehan
Hi folks,
I am willing to buy Gigabyte G41 motherboard for Linux 2,7 wheezy,×64 bit architecture and E8400 core 2 duo 3Ghz 6m processor.
2Gb ddr3 ram and on board vga.
Can i work with linux cnc with lathe?
Can i get lower than 15000ns latency value and jitter value which i have no idea about it yet!
Bonus question?
Is motherboard cause problems with latency test?;i
If ram and processer is enough for give good latency value will motherboard eat latency value?
#realtime lover po rever (for ever)
Thank you
DS
Bonus question?
Thank you
DS
16 Oct 2019 06:39 #147969
by pl7i92
Replied by pl7i92 on topic Gigabyte G41 motherboard
hi the RAM is very low 4GB recomended for 64bit
no matter the latency is only relevant if you plan on softwarestepping PARPORT
if you go ETH it is ""non"" Factor even if it is abaut 200k
if you do like MOST know go for a MESA there are almost every system on hardware stepping
and it can also BRIDGE from ETH to parport with multiple cards
meaning upgrade your parport system by just hooking up a 7i92
that gives hardware stepping to a parport
improving from 50k steps per second to nearly 180k no one needs but can be done
- Dinuka_Shehan
- Topic Author
16 Oct 2019 12:03 #147991
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Gigabyte G41 motherboard
I don't have Mesa card and order online is very expensive.shipping charges too high.
I can use 4gb or more ram for it.
Can i work with this.
23 Oct 2019 22:30 #148638
Replied by andypugh on topic Gigabyte G41 motherboard
It's hard to say for sure unless someone has used the exact same motherboard, but it ought to work.
Does it have an onboard Paralell port, if that is what you intend to use?
- Dinuka_Shehan
- Topic Author
24 Oct 2019 06:29 #148672
by Dinuka_Shehan
Yes it has a on board pp
Time to create page: 0.135 seconds
