LinuxCNC Distro 2.7(.14?): fails "sudo apt-get update"
27 Oct 2019 18:42 #148910
by travis036
LinuxCNC Distro 2.7(.14?): fails "sudo apt-get update" was created by travis036
ok, so i finally got a network connection out to my CNC shed via a KuWfi bridge pair. so anyway, i thought it was about time to run apt-get update, as i never did, due to lack of a network connection out there.
Here is a short summery of the failed update: (full output attached )
i didn't include the whole output as it is quite long. is it safe to say that the distro may be really out of date? i know it is LinuxCNC 2.7, but the exact revision number i am unsure of.
so, how do i update? i have verified that the internet works out there by visiting the linuxcnc.org page.
Thanks in advance for any help.
~Travis
W: Failed to fetch http://http.debian.net/debian/dists/wheezy-updates/main/source/Sources 404 Not Found
W: Failed to fetch http://http.debian.net/debian/dists/wheezy-updates/contrib/source/Sources 404 Not Found
W: Failed to fetch http://http.debian.net/debian/dists/wheezy-updates/non-free/source/Sources 404 Not Found
W: Failed to fetch http://http.debian.net/debian/dists/wheezy-updates/main/binary-i386/Packages 404 Not Found
W: Failed to fetch http://http.debian.net/debian/dists/wheezy-updates/contrib/binary-i386/Packages 404 Not Found
W: Failed to fetch http://http.debian.net/debian/dists/wheezy-updates/non-free/binary-i386/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
~Travis
27 Oct 2019 18:55 - 27 Oct 2019 19:15 #148914
by travis036
Replied by travis036 on topic LinuxCNC Distro 2.7(.14?): fails "sudo apt-get update"
may have found the solution...
linuxcnc.org/docs/2.7/html/getting-start...dating-linuxcnc.html
~Travis
EDIT: yes, i fixed it. i was trying to update the old-fashioned way i guess.
~Travis
Last edit: 27 Oct 2019 19:15 by travis036.
Time to create page: 0.120 seconds
