LinuxCNC + Orange Pi (allwincnc)
- ALittleOffTheRails
- User is blocked
- Thank you received: 65
15 Dec 2021 07:46 #229100
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic LinuxCNC + Orange Pi (allwincnc)
Been following this thread for a while now and been having a play around with a Opi PC, originally I tried a OPi One but that was DOA.
After looking at the OPi schematics I noticed that the majority of the camera connector pins are connected to port E (PE0 - PE15), 2 are connected to port G (PG11 & PG 13) and one to port a (PA17). So that would give an extra 19 pins.
Has anyone tried this yet ?
I've ordered a cable & connector on a breakout board to give it a go, but waiting delivery. Whilst I could probe the pins age is catching up and I don't want to break the SBC.
15 Dec 2021 17:38 #229148
by 109jb
Replied by 109jb on topic LinuxCNC + Orange Pi (allwincnc)
I got a little sidetracked on my OPi project. Have been using it as I had it set up for the mill but have been playing with my new 3d printer and other projects. I still have intentions of using this with 2 MPG wheels for my lathe. Ordered 2 new MPG wheels to test things out.
- User is blocked
15 Dec 2021 21:07 #229164
Yep I'm looking to use mine with a lathe as well, have a couple of encoders on the way as well as a 2nd MPG.
I have been testing with the BoB I made for my BeagleBone black, I think the way forward if the camera connector is usable is a custom board to plug into the aforementioned board.
17 Dec 2021 00:08 #229220
by Cncninja
Replied by Cncninja on topic LinuxCNC + Orange Pi (allwincnc)
I have the H3 board with 2GB's... based on the build a few months ago it would run but choked when a real 3d gcode was loaded. lots of talk about video drivers... has something changed?
- User is blocked
17 Dec 2021 02:09 #229248
Orange Pi Plus 2E ?
The reality of it is is for best performance an x86 platform and MESA is hard to be beat.
That's what I'm using for my mill.
As I had breakout boards I designed for my beagle bone black the OPi looks like a good option for the lathe, as that will be more likely used via the MPGs, threading a taper turning is where I'll see the most use of the full CNC capability.
Remora is great if you are using a 3D printer board, everything is there, but if you intend using a stm32 dev board there is still a lot hardware wise that needs taking into account.
Same as this project, the hardware (level translation) needs to be considered.
The beauty I see in going the MESA route is that you buy a board that is ready to be wired into a system.
If you're into tinkering and have a good basic knowledge of electronics these "side" projects are interesting to get involved in.
I've had no issue with video.....except when running X Axis via an ssh connection.....but that is due to drivers used on the remote machine.
17 Dec 2021 02:35 - 17 Dec 2021 02:36 #229259
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
@ cncninja I only have an old Opi with 512MB of RAM. Boards and time are hard to come by. I expect the situation to be different 6-12 months from now.
@ ALittleOffTheRails yeah many of us have thousands or tens of thousands in tooling. A few hundred $ extra for Mesa is not a problem. This project like some others using very low budget hardware are for those applications where they might have a few hundred total or so in the machine and tooling. They might be exploring how to move more smoothly using LCNC after running their *duinos for a while.
Last edit: 17 Dec 2021 02:36 by Bari.
- User is blocked
17 Dec 2021 03:31 #229264
Oh yeah I fully get that.
I have a foot in both camps.
I really like this Opi Project.
If Linuxcnc supported the PRUSS on the BBB I'd be using it.
17 Dec 2021 17:57 #229321
by Cncninja
It does, Machinkit was an SBC fork of LCNC and is still used on PocketNC 5 axis desktops their new control is BBB based on LCNC and with full 5 axis tool center point control. I'm hoping they will release the code per LCNC lic
- User is blocked
17 Dec 2021 22:35 #229345
Although it was based on Linuxcnc MK development has taken a different path than mainline Linuxcnc. There has been a lot of lowlevel changes made as well.
Machinekit development has been broken it 2 code bases, machinekit-hal & machinekit-cnc. There is also support for web-based interfaces & control, along with machine-talk which is a kind of sever-client model.
I have used Machinekit on the BBB, but switched to Linuxcnc for various resaons.
23 Dec 2021 17:11 #229822
by taylorcmq
Replied by taylorcmq on topic LinuxCNC + Orange Pi (allwincnc)
could you give me these reasons, just out of curiosity, i have never used machinekit but i have heard a lot about it and i would like to know why it has returned to the official linux CNC
Time to create page: 0.148 seconds
