J3455, mid 50k servo jitter and mid 60k base thread ok?
19 May 2020 00:02 #168211
by jhandel
J3455, mid 50k servo jitter and mid 60k base thread ok? was created by jhandel
I have tried everything under the sun with Preempt_rt to get this little J3455 mini-pc (amzn.to/2ZbzSsi) to hit "decent" numbers.. So now I have to wonder, is the machine just not right?
The best numbers I can old are around 50k for servo and 60k for base... I've tried cpu isolation, a ton of other kernel boot settings, custom builds of the kernel, multiple images, etc... Those numbers are with Preempt RT or RTAI...
Before I throw up my hands has anyone else had luck with J3455 procs? is a mid 50k number ok? I am looking to build an EtherCat servo based 5 axis machine and I'll want to push it pretty decently..
Sadly I can't seem to do anything with the fans or the bios (super locked down bios) so it could be that my problem is in parts of the bios that is nuttered.. But before I assume that I figured I would ask if that "feels" normal.
Thanks all
PS: Its not a total waste, I need to update my very aging Mach 4 machine so there is that .. And I can still dev Linux CNC UIs on it.
Thanks all
19 May 2020 00:32 #168215
Replied by cmorley on topic J3455, mid 50k servo jitter and mid 60k base thread ok?
are you using Mesa hardware or parallel ports?
19 May 2020 00:36 #168217
Replied by PCW on topic J3455, mid 50k servo jitter and mid 60k base thread ok?
He said Ethercat, that should probably be OK with 60 usec latency
20 May 2020 13:50 #168382
by jhandel
Replied by jhandel on topic J3455, mid 50k servo jitter and mid 60k base thread ok?
So at what point is Servo thread too slow? and about how much IO & Axises can you "fit" into a given amount of latency before there is a risk of bad results...
Just trying to decide if 50k jitter is going to be sufficient for 5 axis, tool changing, etc...
- Thank you received: 5984
20 May 2020 14:08 #168383
Replied by tommylight on topic J3455, mid 50k servo jitter and mid 60k base thread ok?
That is still usable even for software stepping/parallel port, with somewhat limited velocity.
For hardware stepping it can be much worse and still work properly.
Latency has nothing to do with how many axis or IO are in use.
20 May 2020 14:15 - 20 May 2020 14:16 #168384
The amount of data is not very important as its all very small relative to the data
transmission rate. The effect of latency on axis motion depends on the control
method chosen and whether the hardware has the ability to retime read and write
operations or filter/slew limit velocity or position commands
Assuming a simple position mode system with no re-timing and no filtering, 50 usec of jitter
would cause a 5% error in position updates. For example at say 120 IPM = .002" per mS,
5% = 10 uinch position command noise.
A velocity mode system is less affected by jitter (and unaffected during non accelerated motion )
Last edit: 20 May 2020 14:16 by PCW.
20 May 2020 16:55 #168389
by jhandel
So jitter is more about positional accuracy at any given moment in time and less about "bandwidth" to read/write... Got it.. Thanks
31 Aug 2020 14:23 #180166
by PeterKey
Replied by PeterKey on topic J3455, mid 50k servo jitter and mid 60k base thread ok?
Hello!
Sorry, my reply may be late.
I have a J3455 desktop with Linux Mint LMDE3 and LinuxCNC 2.8. Using an integrated video had a unsatisfactory latency. The discrete videocard lead to make a latency about 15000 despite of any software load.
Time to create page: 0.170 seconds
