monitor res. not reporting correctly (solved)
28 May 2020 16:47 - 28 May 2020 17:01 #169238
by Clive S
monitor res. not reporting correctly (solved) was created by Clive S
solved mint didn't like a usb stick on booting
Last edit: 28 May 2020 17:01 by Clive S. Reason: solved
The following user(s) said Thank You: bbsr_5a
29 May 2020 06:44 #169270
by bbsr_5a
Replied by bbsr_5a on topic monitor res. not reporting correctly (solved)
this is a comen RT kernal problem timing on startup with usb stick connected is different then without
29 May 2020 09:26 #169291
Don't tell Tommy but always burn your bootable USB's with win32diskimager!
Replied by rodw on topic monitor res. not reporting correctly (solved)
29 May 2020 09:49 #169293
by tecno
Works like a champ
Replied by tecno on topic monitor res. not reporting correctly (solved)
Works like a champ
29 May 2020 10:24 #169297
by Clive S
I always burn them with win32siskmanager that was not the problem the pc was loaded with a few configs and I changed the monitor that seemed to indicate it was a res. problem as it was fine at the flash screen but would not work after that just a flashing cursor.
Then I realised I had left a usb stick in with some data on it and the pc would not boot upon removing the usb it booted fine.
Not sure if this is a mint thing.
according to this: forum.linuxcnc.org/18-computer/39193-mon...rectly-solved#169270
Replied by Clive S on topic monitor res. not reporting correctly (solved)
29 May 2020 10:41 #169299
I actually found some more generic Linux forum posts (eg debian or mint forum) that said that there were issues with ISO burning from Linux and to use win32diskimager. Its definitely not a LinuxCNC issue and its not restricted to a specific distro.
29 May 2020 10:48 #169300
by phillc54
Having said that I can't recall any issues with dd but I am getting lazier.
Replied by phillc54 on topic monitor res. not reporting correctly (solved)
Balena Etcher for me, it never misses a beat.I actually found some more generic Linux forum posts (eg debian or mint forum) that said that there were issues with ISO burning from Linux and to use win32diskimager. Its definitely not a LinuxCNC issue and its not restricted to a specific distro.
29 May 2020 11:56 #169308
by Clive S
Ok. I think we are talking at cross purposes here. There is nothing wrong with the iso or the way it was flashed.
The PC was flashed from a usb with mint and I have been using it for several months without issues.
The only trouble I have is that if I leave a usb stick in and then turn the PC on, it hangs and does not boot up if there is no USB stick in it always boots fine.
29 May 2020 12:05 #169309
by phillc54
I don't have that issue on my Mac's
I did see that Clive, sorry I was just waffling on...The only trouble I have is that if I leave a usb stick in and then turn the PC on, it hangs and does not boot up if there is no USB stick in it always boots fine.
- Thank you received: 6268
29 May 2020 13:32 #169316
Replied by tommylight on topic monitor res. not reporting correctly (solved)
I did notice someone went off the rails, so i just hit the brakes !
Time to create page: 0.214 seconds
