What about a DELL OPTIPLEX 760
- macsddau@linuxcnc
- Topic Author
- Thank you received: 28
08 Jul 2020 08:36 #173958
by macsddau@linuxcnc
What about a DELL OPTIPLEX 760 was created by macsddau@linuxcnc
I can find a DELL OPTIPLEX 760 with Dual core e5200 processor. What do you think about this computer for stepping ?
- Thank you received: 5957
08 Jul 2020 10:22 #173963
Replied by tommylight on topic What about a DELL OPTIPLEX 760
It should work fine with Debian Wheezy, if the electronics are OK, but it does not work with new RTAI kernels.
It will work with Preempt-RT kernels, even new ones, but the latency will be bad for software stepping.
Keep in mind that Wheezy is past it's end of life, so there is no support for it and no updates.
It should be possible to install a new version of Linux and the old kernel 3.4.nn and make it work.
The following user(s) said Thank You: macsddau@linuxcnc
- macsddau@linuxcnc
- Topic Author
08 Jul 2020 11:04 #173969
Replied by macsddau@linuxcnc on topic What about a DELL OPTIPLEX 760
Thanks for answer. I will forget this model.
Time to create page: 0.325 seconds
