- Hardware & Machines
- Computers and Hardware
- Just discovered my latency is through the roof, looking for a new ITX MB
- B.Reilly01
- Topic Author
- Thank you received: 12
12 Aug 2020 03:17 #177979
by B.Reilly01
So I just ran latency test and discovered my max jitter was 400,000+ on an old Intel Atom D2550. For a while I've thought this wasn't the best board, so I'm looking for a new MB and CPU. I run a 5i25, so I need a PCI or PCIe with PCIe to PCI adapter. I'd prefer 12V, but that's not a necessity. I'd like ITX or smaller so that it fits into the control cabinet without much fuss. I haven't built a PC in 15 years, so I'm way out of the loop. I want to run Mint with LCNC 2.8, the 5i25 has a 7i77, running 3 analog servo drives and an analog VFD for spindle control on a Hurco mill. I'd prefer not to buy another Mesa card (ethernet) unless I have to. The 5i25 works.
Thank you for your help.
- Thank you received: 5957
12 Aug 2020 06:22 #177987
Replied by tommylight on topic Just discovered my latency is through the roof, looking for a new ITX MB
You can try to use the RTAI kernel and LinuxCNC from here :
www.linuxcnc.org/temp/
-linux-headers-4.14.174-rtai-amd64_4.14.174-rtai-amd64-3_amd64.deb
-linux-image-4.14.174-rtai-amd64_4.14.174-rtai-amd64-3_amd64.deb
-linuxcnc_2.8.0~pre1_amd64.deb
-rtai-modules-4.14.174_5.2.3-linuxcnc_amd64.deb
Install them by double clicking or using gdebi .
- B.Reilly01
- Topic Author
12 Aug 2020 18:58 #178050
by B.Reilly01
Replied by B.Reilly01 on topic Just discovered my latency is through the roof, looking for a new ITX MB
Thanks Tommylight, I'll give this a shot tonight. This is compatible with Mint, yes? I just click through on the mill and install these files?
12 Aug 2020 19:14 #178052
Yes and yes.
- B.Reilly01
- Topic Author
13 Aug 2020 00:37 #178062
by B.Reilly01
So after all that I still have a latency of 140,000ns without really punishing the system. I just opened this window and youtube. Pretty sure the PC is just shot. At idle jitter is 90k ns
13 Aug 2020 06:46 #178068
What does
uname -a
in a terminal say?
uname -a
in a terminal say?
- B.Reilly01
- Topic Author
13 Aug 2020 13:10 #178097
by B.Reilly01
Linux CNCMill-Mint 4.19.106-rt44-lcnc #1 SMP PREEMPT RT Thu Mar 5 00:02:34 AEDT 2020 x86_64 x86_64 x86_64 GNU/Linux
so it looks like the rtai kernel didn't install
13 Aug 2020 14:01 #178099
Maybe it did, but it requires holding down shift button while booting to show the grub menu and there choose the RTAI kernel.
Or you can install grub customizer and use that to make the RTAI entry as default. That is not a typo.
- B.Reilly01
- Topic Author
13 Aug 2020 14:16 #178103
by B.Reilly01
Also, I have a conflict installing linuxcnc_2.8.0~pre1_amd64.deb - it conflicts with the current Linuxcnc-uspace installation.
13 Aug 2020 14:23 - 13 Aug 2020 14:24 #178105
Use synaptic package manager to remove linuxcnc, then install.
Last edit: 13 Aug 2020 14:24 by tommylight. Reason: typo
Time to create page: 0.213 seconds
