Startech PEX2PECP2 Parallel port card
29 Sep 2020 11:48 #184275
by jeoslislo
Startech PEX2PECP2 Parallel port card was created by jeoslislo
I can't seem to get this card to work. Has anyone used this card successfully?
- Thank you received: 5984
29 Sep 2020 11:55 #184276
Replied by tommylight on topic Startech PEX2PECP2 Parallel port card
Insert the card on the PC,
Boot that PC with any Linux,
Open a terminal and type
sudo lspci -v
you should get something like " driver in use parport", so scroll up and write down 2 addresses for IO ports
Use those two addresses to configure LinuxCNC.
sudo lspci -v
29 Sep 2020 12:18 #184281
by jeoslislo
Replied by jeoslislo on topic Startech PEX2PECP2 Parallel port card
I am really having no luck. When I sudo lspci -v with the card not inserted and then sudo lspci -v with the card inserted, the only change in the output is the following additional info, nothing else:
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Prefetchable memory behind bridge: 00000000f0000000-00000000f00fffff
Capabilities: <access denied>
Kernel driver in use: pcieport
06 Oct 2020 09:01 #185041
by seuchato
Replied by seuchato on topic Startech PEX2PECP2 Parallel port card
try
ls -l /proc/sys/dev/parport
06 Oct 2020 11:39 #185052
by jeoslislo
Results with TWO different parallel cards plugged in:
shop@shop:~$ ls -l /proc/sys/dev/parport
total 0
dr-xr-xr-x 1 root root 0 Oct 6 07:29 default
shop@shop:~$
total 0
shop@shop:~$
- Thank you received: 1370
06 Oct 2020 17:55 #185105
Replied by Todd Zuercher on topic Startech PEX2PECP2 Parallel port card
But that only tells you that the parallel port card isn't supported by the kernel. It could still possibly work with Linuxcnc using the correct memory address.
PCIe parallel port card support is a bit sketchy, but I believe that has more to do with problems with the cards themselves. The really problematic ones are more parallel port emulators than actual proper parallel ports.
The following user(s) said Thank You: BeagleBrainz
06 Oct 2020 19:27 - 06 Oct 2020 19:36 #185119
by seuchato
did you disable the pci/pce slots the cards are plugged i in bios?
also try this:
tech specs found here say "Chipset ID ASIX - MCS9865". According to this post , it should "work fine".
also try this:
dmesg | grep par
[ 3.974443] parport_pc 00:02: reported by Plug and Play ACPI
[ 3.979007] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
Last edit: 06 Oct 2020 19:36 by seuchato. Reason: hint on dmesgm tecg specs and faq pci parport added
06 Oct 2020 22:11 #185147
A few days back i did test a StarTech PCI to parallel port card that did not work at all with Linux, the board is plain and void of any parts besides a small chip.
Used a NetMos card that always works.
The StarTech is recognized only as a PCI card under Linux, did not test any further.
06 Oct 2020 22:22 - 06 Oct 2020 22:24 #185150
by Clive S
I purchased 5 of these and they all work fine.
www.ebay.co.uk/itm/5-x-Startech-PEX1P-Pa...p2057872.m2749.l2649
edit I noticed they are back on there website at the same price
Replied by Clive S on topic Startech PEX2PECP2 Parallel port card
TomA few days back i did test a StarTech PCI to parallel port card that did not work at all with Linux, the board is plain and void of any parts besides a small chip.
Last edit: 06 Oct 2020 22:24 by Clive S.
06 Oct 2020 22:29 #185152
I had a PCI one, not PCI-e, with a very small chip on it and nothing more, not even a resistor.
These on your link have some more electronic on them and a much bigger chip.
Never bothered to look at the chip no.
Nice !I purchased 5 of these and they all work fine.
Time to create page: 0.190 seconds
