Will this computer work?
07 Oct 2020 14:26 #185255
by jrmm
Will this computer work? was created by jrmm
Hello- I have a homebuilt CNC with large enough work area to handle 48" x 96" mterial.
My controller is Hobby CNC Prox 4 Axis.
I mirror 2 steppers for X Axis.
Have been using Mach3 for around 10 years and would like to transition to LinuxCNC.
I have a really old computer that is failing.
I set up Dual boot with Linux CNC about a year ago and did a quick proof of concept with it.
I am wanting to replace the computer and would like to get some thoughts on the setup below.
Do you see any concerns or have suggestions?
I would like to Dual boot with Windows 10 so that I can run Windows software as well in my shop. (v-carve Pro, Lightburn, etc)
Computer: Tangent Rugged Mini L2 -- www.tangent.com/industrial-computer/rugged-mini-pc/L2#tabs-2
Can you run a CNC off the 2 built in Serial Ports? I'm guessing no.
Would a Mini Pcie adapter like this work? : www.newegg.com/p/17Z-00PR-00JY3
Planned Upgrades: 16 GB RAM , Lexar NS100 128GB SSD
Thanks very much i advance for any feedback and for all you do.
LinuxCNC looks to be an amazing product of hard work.
- John
- John
- Thank you received: 5984
07 Oct 2020 16:42 #185279
Replied by tommylight on topic Will this computer work?
Normal SFF PC, 8GB RAM, SSD and a Mesa 7i92 or 7i96 or 7i76E.
Most probably all of that will cost less than that "Industrial" PC in a car power amplifier box with just a normal ITX board inside.
07 Oct 2020 17:10 #185283
by jrmm
Replied by jrmm on topic Will this computer work?
Tommylight - - Thanks very much for your feedback. I'll look into that.... I already have the Tangent fanless PC - It was given to me through my employer with the HDD removed. I purchased the SSD to put in it already. It currently has 4GB RAM, but I plan to upgrade to 16GB (Max it supports) mostly for windows.
My shop is dusty - being fanless is appealing to me.
- John
- John
- BeagleBrainz
- User is blocked
- Thank you received: 570
07 Oct 2020 17:20 #185284
by BeagleBrainz
Replied by BeagleBrainz on topic Will this computer work?
Download an iso and run a latency test.
+1 for the mesa route. Well worth the little extra, and no having to worry about parallel ports when the computer goes bye bye. As long as it has an Ethernet port you’re more or less good to go.
One thing to think of, do you really want to reboot every time you want to change your drawing or redo your CAM ? If that is the plan.
07 Oct 2020 18:26 #185289
by jrmm
Thanks... I'll do the latency test in next day or so.
I'm unfamiliar with the mesa route. Are you talking about this:
store.mesanet.com/index.php?route=produc...t_id=302&search=7i92
Do you need direct network cable/ crossover... or can it be on LAN?
And would this mesa then communicate to my Hobby CNC controller?
I'm new to this... I'll have to do some reading to get up to speed.
07 Oct 2020 23:06 #185311
Yes that is the 7i92, it does work like 2 parallel ports, or whatever else is needed as it is programmable and it is much, much faster than parallel port.
It does use direct cable connection to the PC, but the cable can be whatever as all the new ethernet ports have "auto negotiation" feature.
- BeagleBrainz
- User is blocked
08 Oct 2020 04:02 #185326
by BeagleBrainz
It's amazing what you learn.
I always thought a straight thru cable was needed. Not that I have tried with a X-over cable. Geeze I don't think I've used one in ages.
- BeagleBrainz
- User is blocked
08 Oct 2020 04:18 #185328
by BeagleBrainz
Think of it as this.
Once you connect the 7i92 to your PC it's like having a parallel port that Linuxcnc can talk to. And rather than the computer doing the timing the 7i92 creates the timing signal, but unlike the boards the work with Mach Linuxcnc is still in control of planning the motion.
So that would mean, in a nut shell, if you have a cnc machine controlled via a parallel port the 7i92 can replace the parallel port. Also the 7i92 has a second set of 17 signals that can be configured in other ways.
Plus there's a wealth of knowledge and Mesa support is great on the forum.
I look at it this way. You're spending a fair wedge of beer tokens on your cnc machine, why not spend a little extra on some really good hardware.
I had a look at what the Mach Licences cost and if your are starting from scratch and need to get a Licensed copy of Mach3/4 a basic Mesa card is less. Plus there is no need to buy a Windows Licence either.
Plus the CAD & CAM options seem to be getting better for the Linux platforms.
Not everyone is going to feel comfortable with Linux and that's ok.
Ok enough rambling and carrying on like Abe Simpson...now where's my turnips ?
The following user(s) said Thank You: seuchato, tommylight
Time to create page: 0.146 seconds
