Latency test questions
12 Oct 2020 17:45 #185859
by txtrone
Latency test questions was created by txtrone
Toward the end of the latency test results, there are a couple of lines that read like this:
XXXX secs servo min:-XX.XXX uS max: XX.XX uS sdev: X.XXX uS
I understand the first XXXX secs as being where the reading is taken from, 3600 is one hour in, etc
What do the rest mean?
servo min
uS max
uS sdev
uS
To me it seems that the lower the value on those 4 parameters, the better... but that is all I have derived. Thanks.
servo min
uS max
uS sdev
uS
20 Oct 2020 00:54 #186641
by seuchato
If you mean lcnc-hw, then those two lines at the end are just exactly the two lines of the xyz.lat file the script generates. I am currently struggling to ad a graphical output.
AFAIK for servo based systems (ie.: mesa ethernet) tommylight used to call anything below 100 uS as good. From my own experience, with a rather slow (1800mm/min) bridge mill on parallelport, I had no issues with 50 uS.
These figures are just orientation values. As others have pointed out:
a) your system may behave somewhat different when making chips
b) looking at the myriad of variations (CPU, GPU, Disc, Mobo, Bios version, OS flavour and version and update state plus bugs, interfaces, electronic components, environment...) there cannot be a single good value. But I do agree, the current span is too wide.
As for the individual labels:
"XXXX secs" is the runtime of the latency histogram run. I set the default run time to 7200 secs (2h) because my small bridge mill rarely has jobs that last longer and more important, I did not see one case where big changes occurred after 1 hour. So to play it safe: make it two hours
"servo" means the line addresses data for the serve thread. You could trigger also a base thread. That is only suitable if you plan to use a parallel port based set up
"min" is the minmal time say "shift" away from expected response and
"max" the positive
"stdev" is the standard deviation of the data, I am not sure on how many samples this is based
hth
chris
PS: I'll put a link to this in the thread for lcnc-hw , where I feel your question would also have been nicely at home
Replied by seuchato on topic Latency test questions
servo min
uS max
uS sdev
uS
"max" the positive
hth
chris
20 Oct 2020 18:11 #186718
by txtrone
By that do you mean the current span of 50uS - 100uS ?
Thanks for the clarifications and your hard work on this for the community!
Replied by txtrone on topic Latency test questions
20 Oct 2020 18:44 #186722
by seuchato
Yes and no. Yes because I figure tommylight has much more knowledge than mysel. No because I saw figures accepted as good in other threads that are well over the said 50 for base and 100 for servo.
... and thanks for the flowers.
- Thank you received: 5984
20 Oct 2020 20:04 #186738
Replied by tommylight on topic Latency test questions
Almost everything with a STABLE latency of UP TO 300000 can be used without any issues when considering their limitations for software stepping using a parallel port that will greatly limit the steps per second that the PC can safely produce.
For Mesa boards i am sure latency of over 200000 is all good as i use two laptops daily with such latency, both work perfectly and never drop the link to Mesa 7i92, although one of them will rarely complain about latency errors but not every day and never drop the link.
21 Oct 2020 08:41 #186798
by seuchato
Tommylight: Thanks for the clarification. Is it OK, if I use our above post as a hint to reference indication from my script?
For parallel based systems, there is the Step Timing Calculator and valuable reading here . I recommend reading the whole chapter .
I will add this as reference hint, if the script is run with a base thread.
greez
chris
greez
chris
