- Hardware & Machines
- Computers and OS's
- Debian Buster 10 + Linuxcnc + Ethercat + ISO cd Download 1.7 GB
05 Jun 2021 19:04 #211242
by nic
Replied by nic on topic Debian Buster 10 + Linuxcnc + Ethercat + ISO cd Download 1.7 GB
Hi Grotius,
it`s strange but I have used the same hard disk. I think debian don`t like my new amd gpu. I fixed it already (after 3h .. xD) with the amd firmware.
Thank`s a lot anyway for your answer.
Is the Linux 11 in your opinion better than buster?
Best regards,
Nic
Best regards,
Nic
29 Mar 2022 19:31 #238638
by LAUSCH
Replied by LAUSCH on topic Debian Buster 10 + Linuxcnc + Ethercat + ISO cd Download 1.7 GB
Hi all,
When I ran the Ethercat_installer.sh it end up with the following error message:
$ ip a revealed that my network device is not called enp0s25
following approached solved the issue:
Afterwards i ran "Ethercat_installer" again and it executed successfully.
cat: /sys/class/net/enp0s25/address: No such file or directory
.. Retrieved MAC adres :
.. .. Appending MAC adres to last line of ethercat file /etc/default/
make: Entering directory '/usr/share/ethercat/linuxcnc_ethercat'
make[1]: Entering directory '/usr/share/ethercat/linuxcnc_ethercat/src'
make[2]: Entering directory '/usr/share/ethercat/linuxcnc_ethercat/src'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/usr/share/ethercat/linuxcnc_ethercat/src'
make[1]: Leaving directory '/usr/share/ethercat/linuxcnc_ethercat/src'
make: Leaving directory '/usr/share/ethercat/linuxcnc_ethercat'
Compiling the linuxcnc-ethercat lcec driver
Updating EtherCAT master confiuration
modprobe: ERROR: could not insert 'ec_master': Invalid argument
failed!
Job for systemd-modules-load.service failed because the control process exited with error code.
See "systemctl status systemd-modules-load.service" and "journalctl -xe" for details.
$ sudo ip link set <your network device name> down
$ sudo ip link set dev <your network device name> name enp0s25
$ sudo ip link set enp0s25 up
$ sudo ip a
- Sockheaven
- Thank you received: 10
13 Sep 2023 18:07 #280660
by Sockheaven
Replied by Sockheaven on topic Debian Buster 10 + Linuxcnc + Ethercat + ISO cd Download 1.7 GB
Hi All,
I am about to start bringing up a new machine next month and getting my resources all together.
I will try using the most recent ISO that was posted here, but it leads me to ask the question "Is there a plan to include the EtherCAT support into the standard download"?
I'd love to see this happen instead of relying on frozen builds (forgive my ignorance if there is an easy way to upgrade once installed on a machine - my experience with Linux doesn't go much further than what I have learned getting LinuxCNC up and running).
I suspect the EtherCAT support would make the Raspberry Pi build work quite well too as it would eliminate the need for external Mesa Boards and the configuration that entails.
Best Regards,
Paul
Best Regards,
Paul
14 Sep 2023 09:40 #280722
Replied by rodw on topic Debian Buster 10 + Linuxcnc + Ethercat + ISO cd Download 1.7 GB
This ISO forum.linuxcnc.org/9-installing-linuxcnc...or-linuxcnc-x86-only
includes the ethercat repositories and also this shows how to install ethercat on that ISO these days.
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
I have built an image for the pi linked on the frum here but have not included ethercat repos. etherlabmaster have told me they are hosting packages for the pi but I was not certain that I could build the ethercat hal driver and add the packages to my repository. The hal driver should build from source. Try my fork of it here whcih is what I build the debs i uploaded. github.com/rodw-au/linuxcnc-ethercat
There are some liciencing issues preventing linuxcnc from including ethercat stuff but by including the repositorises in our sources.list should not break any rules..
The following user(s) said Thank You: Sockheaven
- Sockheaven
14 Sep 2023 14:04 #280743
by Sockheaven
Ahh bummer on the licensing.
Thanks for the info, I was wondering why this hadn't made it into the standard build.
Best Regards,
Paul
Best Regards,
Paul
14 Sep 2023 20:57 #280783
My ISO is not really frozen. to get the latest linuxcnc and ethercat, you just need to type
sudo apt update
sudo apt upgrade
This will get linuxcnc as of the date you do it.
sudo apt update
sudo apt upgrade
- Sockheaven
15 Sep 2023 13:35 #280847
by Sockheaven
OH - never considered doing that. Thanks!
- Sockheaven
10 Nov 2023 17:26 #285036
by Sockheaven
I seem to be having issues using the upgrade command.
I was on LinuxCNC 2.8.4 and am prepping for a new machine build next week. decided to try the upgrade path mentioned above:
sudo apt update
sudo apt upgrade
While the procedure seems to have done "something" LinuxCNC remained at 2.8.4.
Another oddity is that when i tried to start my project (using the etherlab master that was previously installed) the ec_generic controller appears to be removed from the computer.
Startup error:
Failed to open /dev/EtherCAT0: No such file or directory
LCEC: requesting master 0 (index 0) failed
lcec: rtapi_app_main: Invalid argument (-22)
If i try to re-run teh "ethercat_installer" that comes with that ISO, it fails near the end with this error:
modinfo: ERROR: Module ec_generic not found.
I'm going to just re-install at this point, but I have had similar issues on other computers trying to update debian, feels like i'm missing a key step somewhere.
Best Regards,
Paul
sudo apt update
sudo apt upgrade
Startup error:
Best Regards,
Paul
10 Nov 2023 21:19 #285052
Am upgrade keeps you on the same debian version and just install any new releases in that version.
You can't just install ethercat and expect it to work. Please follow my stickyed instructions in the ethercat section of the forum to configure it.
I honestly think you would be better off installing the new Debian Bookworm 2.9.1 ISO from linuxcnc's download page.
Whilst it is possible to use sudo apt-get dist-upgrade to upgrade from Buster to later releases, I would not recommend this path as it is very time consuming and takes a lot longer than installing from the iso
The good news from an email last night is Sasha Ittner's linuxcnc ethercat driver is now hosted in etherlabmaster repository so there is no need to bother with compiling it from source. And I don't need to host it on package.io any longer.
Time to create page: 0.167 seconds
