Computer Cooling
- my1987toyota
- Topic Author
- Thank you received: 280
16 Oct 2020 17:57 #186299
by my1987toyota
Computer Cooling was created by my1987toyota
So I am in the midst of decision / information overload . I await the arrival of my G0602Z lathe and am in
the process of designing the CNC control cabinet.
As usual I am probably over thinking things . I am trying to figure out the best way to keep the computer cool
and as maintenance free as possible.
Seeing that it most likely will not be in an air conditioned environment I have a few questions.
Is it best to use filtered air to cool the control cabinet?
or
Should I seal the control cabinet and use some form of heat exchanger ?
What is the usual heat tolerance or most SFF pc's?
I have used laptops in garages with 90 to 100 degree Fahrenheit temps but not on a daily basis.
Thoughts ?
or
Thoughts ?
- Thank you received: 5984
16 Oct 2020 20:48 #186308
Replied by tommylight on topic Computer Cooling
Seen some working at 55 C inside the box with no issues.What is the usual heat tolerance or most SFF pc's?
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Topic Author
16 Oct 2020 21:09 #186313
by my1987toyota
Replied by my1987toyota on topic Computer Cooling
[/quote]
Seen some working at 55 C inside the box with no issues.[/quote]
that's good to know . As long as I keep power supplies in the cooling air flow after
the mother board I should be fine. I am a bit of a fan of torroidal power supplies .
Glad I don't have to worry about any internal to external heat exchanger system.
Still trying to figure out a filtered air system.
16 Oct 2020 21:21 #186315
I do have some huge ones on the Mazak !Glad I don't have to worry about any internal to external heat exchanger system.
16 Oct 2020 22:20 #186324
Replied by rodw on topic Computer Cooling
I don't think you'll have any problems. We get up to 110 in this country without issue. some of the single board pcs have an external cpu fan so maybe use that. I pi\ut a fan in my enclosure so it draws air diagonally through from another opeining. some of the A/C filter material might be handy.
- BeagleBrainz
- User is blocked
- Thank you received: 570
17 Oct 2020 00:29 #186335
by BeagleBrainz
Replied by BeagleBrainz on topic Computer Cooling
100F yeah just a usual summer day.
Keeping the CPU free of dust will help keep the temps at a reasonable level. Think about component placement as well.
Best thing to do is build it, keep an eye on it and make any changes as required.
17 Oct 2020 16:03 #186369
by fc60
Replied by fc60 on topic Computer Cooling
Greetings,
This past Summer, my machine would "lock up" in the middle of a program. CPU temp was 110F.
On the motherboard are spare connector pins for fans. Some even read "Smart Fans".
I connected an extra fan to move the air away from the Mother Board and things improved.
My CNC control cabinet is not the best design and heat is an issue. Later models came with large fans cut into the electrical cabinet.
The cooler the better, in my opinion.
Cheers,
Dave
Cheers,
Dave
- my1987toyota
- Topic Author
17 Oct 2020 23:52 #186422
by my1987toyota
I agree. I just don't want to have to install an air conditioner in the electrics cabinet .
Cheers,
Dave
Time to create page: 0.230 seconds
