RPi4 image has ssh disabled by default?
19 Oct 2020 20:38 #186617
by mgmatteo
RPi4 image has ssh disabled by default? was created by mgmatteo
I just downloaded the precompiled image for the raspberry pi 4. Since I'm running headless I was planning to connect using ssh and enable a remote desktop server like VNC.
Unfortunately SSH connections are refused, so I tried to manually create the empty ssh file in the boot directory to enable it, but without any luck.
Does anybody knows if running the precompiled image it's possible only using a screen + keyboard? Any possibility to connect using a remote host?
Thank you
Thank you
20 Oct 2020 00:12 #186636
by seuchato
Replied by seuchato on topic RPi4 image has ssh disabled by default?
As fa as I remember: yes, but can be easily changed with "raspi-config". in debian, you might need to install ssh related packages.
hth
chris
hth
chris
20 Oct 2020 07:29 #186658
by mgmatteo
Replied by mgmatteo on topic RPi4 image has ssh disabled by default?
Yes thank you, unfortunately to access raspi-config I have to connect a monitor and... i don't have the micro-hdmi - hmi cable..
I ordered one today.
So if I'm corrected SSH has been removed from the distro, and not just disabled, otherwise I could have been able to reactivate it simply putting the empty file "ssh" in the boot directory of the sd card using my pc.
I think that it would be more usefull to just deactivate it to frre som resource bun leaving it installed (sd space it's not a problem at all)
20 Oct 2020 10:44 #186667
by seuchato
to me ssh is just vital. I do not see it using much resources. However, if it was not considered for the RPi distro, the guys certainly had a good reason for it. Me too, I would always have iut reinstalled.
If you use the Pi to make chips, then certainly you will also want to have a display.
Greez
chris
Greez
chris
20 Oct 2020 13:51 #186681
Replied by andypugh on topic RPi4 image has ssh disabled by default?
I will consider putting it in if we re-release the Pi image. I think it should be enabled by default.
Time to create page: 0.076 seconds
