Shuttle X50V2 all-in-one?
29 Jan 2021 17:27 #197079
by evo
Shuttle X50V2 all-in-one? was created by evo
Hi all,
I would like to get an all-in-one computer with touch screen for controlling a Stepcraft. This computer will be dedicated to LinuxCNC (GUI for checking and running the router), even CAM will be done on a different box. I'll mount it on a stand, so no space taken up by keyboard and mouse and no cable clutter.
At first I thought about getting a (new) Shuttle XPC X50V6U3, but then I though that would be overkill (@ €400) and I found a used Shuttle X50V2 with built-in parallel port for a lot less. The specs are:
(15.6”) touchscreen (1366x768)
Integrated graphics (GMA3150, DX9)
CPU: Intel ATOM D525 Dual Core , 1.8GHz
Chipset: NM10 (Plattform Controller Hub)
4GB DDR3-667/800 (2x 204 pin SO-DIMM)
2x RS232
1x LPT (PCL68)
Is it worth giving this a go, or is that going to be a project on its own getting that to run with (RT) Linux?
2x RS232
1x LPT (PCL68)
30 Jan 2021 00:55 #197106
Replied by andypugh on topic Shuttle X50V2 all-in-one?
I would expect that to work fine. But it might need the RTAI kernel rather than the preempt-rt one of you are software-stepping.
My mill runs with an Atom D525.
- krzychencjusz
10 Oct 2022 17:35 - 10 Oct 2022 17:35 #253897
by krzychencjusz
Replied by krzychencjusz on topic Shuttle X50V2 all-in-one?
Hello, how ended up your story? Did you tried to run it under LINUXCNC?
Last edit: 10 Oct 2022 17:35 by krzychencjusz.
Time to create page: 0.151 seconds
