RPi image (MESA eth)
23 Feb 2021 19:56 - 23 Feb 2021 20:07 #199887
by tecno
RPi image (MESA eth) was created by tecno
Looking for image of latest LCNC/Debian that works! The one on the download page is not working well!
Installed it hangs, no keyboard from boot to next, static IP impossible to set etc....
Last edit: 23 Feb 2021 20:07 by tecno.
- Mike_Eitel
- Thank you received: 185
23 Feb 2021 21:12 #199891
by Mike_Eitel
Replied by Mike_Eitel on topic RPi image (MESA eth)
Hi tecno
Just an hour ago I downloaded www.linuxcnc.org/iso/linuxcnc-2.8.1-pi4.zip
Installed: All fine! Latency ca 22k.
Before I had the pi4 updated with latest 32 bis full-upgrade. And set to usb boot.
I run m2 ssd, xrdp and/or local 1024/768 hdmi screen with usb-bluetooth mini keyboard.
AXIS sim runs very nice and slim.
All just for interest, no real hw in mind.
Mike
Mike
The following user(s) said Thank You: tecno
23 Feb 2021 21:50 #199896
by tecno
Replied by tecno on topic RPi image (MESA eth)
Thanks Mike
will test tomorrow
will test tomorrow
24 Feb 2021 10:45 #199953
by tecno
Sorry to say but this image has serious problems on my RPi.
NO ETH0 = will not accept STATIC 10.10.10.11
Funny behaviour on USB ports
i@pi4-mate:~ $ cat /proc/cpuinfo | grep 'Revision' | awk '{print $3}'
c03111
pi@pi4-mate:~ $ cat /proc/device-tree/model
Raspberry Pi 4 Model B Rev 1.1pi@pi4-mate:~ $
Using my old config with mate with USB boot and USB works OK with Touch and I can run xhc-whb04b-6 -ue
c03111
- Mike_Eitel
24 Feb 2021 15:40 #199992
by Mike_Eitel
How did you try to config eth0. A lot around network configuration changed. You have to do in dhcpd.conf direct in /etc...
AFIR, Sorry on the road
Mike
Mike
24 Feb 2021 15:51 #199995
by tecno
Tried all ways
Obviously there is also this USB issue on RPi4 4GB.
Had some glitches on my old MATE config during the day.
Pie4 is overheating = can not handle needed power on ports. Alu case for cooling.
Installed external powered USB hub and it looks like the heat issue is gone.
Cheers
Bengt
Cheers
Bengt
- Mike_Eitel
24 Feb 2021 16:55 #200002
by Mike_Eitel
Hi tecno
Ask Andy how he configures eth0. Have not tried to connect a Mesa to the pi, gave it only 10min yesterday evening so I can not speak about that. But I think his lcnc is based on latest raspbian and that does not support old way of etc/interfaces anymore.
I remember that heat was a problem on first sw. Have you tried to upgrade to newest bios? And enabled booting from usb?
Mike
Mike
24 Feb 2021 19:37 #200015
by tecno
Will not go the Debian road for now.
I have it (Mate) working and now fighting with MPG hal having issues to get encoder in and out to drivers.
- Mike_Eitel
24 Feb 2021 19:44 #200018
by Mike_Eitel
Sorry don't understand. Do you mean that you stay on the older pi-version, with runs for you?
And yes if something works, why upgrading? I always : What's your pain that you have to upgrade (.... to new, unknown problems....) ;-()
Mike
Mike
24 Feb 2021 20:34 #200021
by tecno
I had some issues (and still have) but it got worse with the new Debian/2.8.1
So better to run my Mate that I compiled last year, all updated. This is the first time I have a USB MPG (xhc-lhb04-6) it the fixed USB variant of (xhc-whb04b-6)
Trying to wrap my head around the needed hal but can not get it to work.
In test mode all buttons etc work just fine.
Time to create page: 0.455 seconds
