Remora - ethernet NVEM cnc board
- vpomerleau
05 Mar 2024 01:19 #295175
by vpomerleau
Replied by vpomerleau on topic Remora - ethernet NVEM cnc board
@Cold Turkey
It is for EC500 RT1052
- Cold Turkey
- Thank you received: 9
05 Mar 2024 01:22 #295176
by Cold Turkey
Replied by Cold Turkey on topic Remora - ethernet NVEM cnc board
Thanks, I tested on mine and get nothing from pins 1,5,9,13 and 14 on the MPG port
- vpomerleau
05 Mar 2024 01:29 #295177
by vpomerleau
For pin 1 and 9 you need the swich on the controller set to standard mpg to test them
- Cold Turkey
05 Mar 2024 01:33 #295178
by Cold Turkey
Yeah mate, I did that.
- vpomerleau
05 Mar 2024 02:15 #295181
by vpomerleau
Maybe controller version is different, I got May 2023... how do you make your tests? Are you louking at remora input or nvmpg inputs in halshow? I use the connector that came with the controller and screw a wire in pin 10 (com ground) and touch the other pins with the other end of the wire, the checked the remora.input.xx
- Cold Turkey
05 Mar 2024 02:23 #295183
by Cold Turkey
My controllers are from multiple batches. Watching remora.input in Halshow. I have the other pins working and yes I'm using the same testing methodology as you. I will try another controller when I get the opportunity.
Thanks for the replies.
- vpomerleau
05 Mar 2024 10:53 #295213
by vpomerleau
@ Cold Turkey
I found an extra blank line in the config file I uploaded, not sure if it's what's causing your problem, I replaced it in my original post.
If you want to make more tests, here's the pins that are used in the github config file. Every other pins can be tested.
P3_12
P3_14 @ P3_20
P3_22 @ P3_26
P4_00 @ P4_15
P4_24 @ P4_25
P4_27 @ P4_31
P3_12
P3_14 @ P3_20
P3_22 @ P3_26
P4_00 @ P4_15
P4_24 @ P4_25
P4_27 @ P4_31
- Cold Turkey
05 Mar 2024 21:20 #295259
by Cold Turkey
Yeah thanks for that, I had already tested the range that had not yet been assigned but got no results. I may have bad hardware.
- Cold Turkey
05 Mar 2024 23:49 #295272
by Cold Turkey
Ok, combination of bad hardware and configs failing to load to the board correctly. Tested your config on a third EC500 and can confirm it is working.
The main EC500 I've been testing on simply has dead pins, I was never going to be able to find them with it. (the oldest board I have, has been through a lot). The second one I killed due to a messy test bench setup and user error.
Had a couple of strange issues with the config not fully overwriting the old one but a full chip erase with pyocd and firmware reflash got it all working as it should.
Thank you for your efforts
07 Mar 2024 00:42 #295367
by cncmiljc
Replied by cncmiljc on topic Remora - ethernet NVEM cnc board
Can you help me with this doubt? With the modified stlink, can I write the Firmware directly through CubeIDE?
Time to create page: 0.182 seconds
