backup to usb and full restore to HDD?
- robertspark
- Thank you received: 216
21 May 2022 19:03 #243499
by robertspark
backup to usb and full restore to HDD? was created by robertspark
in need of some guidance, I am looking for a means to backup a working configuration (full install) onto an SD card so that it can be restored via a bootable USB and a simple gui / menu to restore the backup completely to the hdd.
HDD is 16gb
SD card is 32gb
have looked at various options (systemrestore and other similar variants)
I am aware of and have used DD to clone a HDD to a second HDD .... but I'm looking for a usb stick solution (bootable)
anyone got any suggestions?
anyone do / done something like this before?
HDD is 16gb
SD card is 32gb
- Thank you received: 6006
21 May 2022 22:54 #243507
Replied by tommylight on topic backup to usb and full restore to HDD?
Ventoy = www.ventoy.net/
or
Multisystem = liveusb.info/dotclear/index.php?pages/install
and
CloneZilla = clonezilla.org/
Mind the "or".
CloneZilla creates and restores backups, but does not take ages as it saves only sectors with data. Also does not restore to a smaller dist than the originating one (well it does, but not always).
Might not be important info, but i carry two USb sticks with those always for over 15 or more years, great tools.
or
and
Mind the "or".
The following user(s) said Thank You: robertspark
- robertspark
22 May 2022 06:26 #243532
by robertspark
Replied by robertspark on topic backup to usb and full restore to HDD?
thanks Tommy,
I came across rescuezilla ast night, and gave it a go, very quick and idiot proof
clonezilla + a GUI as an Ubuntu iso
rescuezilla.com/
I'll take a look at your posts too thanks very much for taking the time
rescuezilla.com/
23 May 2022 22:13 #243643
Replied by andypugh on topic backup to usb and full restore to HDD?
If you just want to get back to a LinuxCNC install, copy the linuxcnc directory to USB and reinstall from the ISO disc.
- robertspark
24 May 2022 07:32 #243667
by robertspark
thanks but I was looking for a quick way to do a complete reset if someone messes everything up or does something daft.
for myself I just backup the linuxcnc folder and reuse it on other machines.
I was also looking for a quick restore if a HDD failure occurred.
saves having to reinstall the linuxcnc.iso / Debian and copy it to flash drive etc.
I was surprised how quick it was to backup and restore the drive using rescuezilla.
24 May 2022 13:00 #243682
You _could_ add your working config to the ISO builder and make a new ISO.
Put the linuxcnc folder in here:
github.com/LinuxCNC/buster-live-build/tr...g/includes.installer
and add the default user name to the preseed file.
(I don't guarantee this to be as easy as I just suggested)
- robertspark
24 May 2022 17:49 #243709
by robertspark
how does that work?
presume just clone it to the local HDD and then just run the sudo commands in the readme file?
- robertspark
24 May 2022 17:51 #243710
by robertspark
you've got me reading
live-team.pages.debian.net/live-manual/h...allation.en.html#121
