Axnew Industrial Touch Monitor
16 Aug 2022 03:51 - 16 Aug 2022 03:54 #249849
by kiki09
Axnew Industrial Touch Monitor was created by kiki09
Industrial touch screen monitors
are designed and tested for harsher environments making them much more rugged, compared to typical “office” monitors. They are designed to withstand prolonged shock & vibration, a wide temperature range, and protection from water and dust.
Our high brightness/sunlight readable monitors are ideal for applications in Industrial Automation, Healthcare, Finance/Banking, Education, Gaming/Entertainment, Home Automation, Retail, and Transportation, and pair easily with our Box PCs and Headless HMIs. All our monitors allow you to use gloves and act as touchscreens, reducing the need for a keyboard and mouse allowing for maximum freedom when designing a system.
Axnew Display Technology Co., Ltd. , premier manufacturer of industrial and commercial grade LCD display solution since 2009. Already a leader in customizable open frame LCD displays, the Axnew Industrial Touch Monitor fills the need for projects where an enclosed yet sleek LCD display is desired. Panels in both standard brightness as well as high bright (sunlight readable), standard viewing of full 178/178-degree wide viewing are available. Display connection using VGA, DVI, HDMI, and Composite video are available to adapt to any video input. The Axnew Industrial Touch Monitor allows wide temperature range and wider electrical input (12V DC, 24V DC and 9-36V DC) options that can be customized to requirement. The Axnew Industrial Touch Monitor can fit into any project or specifications.
Axnew is a global display supplier. Our owned developed A/D board and monitors are passed the industrial testing and got the CE, FCC, Rohs Certificates. Click the link to find the monitor you need!
Axnew
www.axnew.com/products/
Axnew
Last edit: 16 Aug 2022 03:54 by kiki09.
- Thank you received: 5946
16 Aug 2022 10:33 #249877
Replied by tommylight on topic Axnew Industrial Touch Monitor
Spam ?
26 Aug 2022 14:12 #250511
Replied by andypugh on topic Axnew Industrial Touch Monitor
It's awkward. It's spam but it's relevant spam.
Time to create page: 0.087 seconds
