Support structure and upgrades
21 Aug 2022 21:56 #250165
by TglEMC
Support structure and upgrades was created by TglEMC
I am relatively new to LinuxCNC, only a few years under my belt, but I am an old worn out hat when it comes to systems, networks, applications and development, just not for Linux. I have a high level of respect for what you all have accomplished in opensource Linux over the over the last 30 years.
I need to have a better understanding of your support structure. I have recently debugged a problem with my Debian 9 stretch system that causes the installation to crash within a couple of days. I am well aware that this installation is no longer supported but I have not been able to find a good replacement. That is not the purpose of this thread.
Refer to my Debian thread: forums.debian.net/viewtopic.php?f=5&t=152665
Perhaps I should have opened this here. I seem to be getting pushback from Debian support saying this is not a Debian problem. I view LinuxCNC as a subsystem, or module, installed on top of a Debian 9 OS, and other applications and network under the OS umbrella. Please tell me if this is incorrect.
Ultimately, this problem was caused by a Buster update being applied to Stretch updates from the source deb deb.debian.org/debian/ stretch main non-free contrib. The bad update is amd64-microcode. Who in the support schema controls this?
I would also like to know what the support schema is for network, and desktop applications.
Thank you in advance
21 Aug 2022 23:24 #250172
by arvidb
Replied by arvidb on topic Support structure and upgrades
The "support schema" is that people help out, in their spare time, when they can and feel like it. It's a pretty helpful community where many people try to help each other out.
That said, please keep in mind when you ask questions that you are actually asking people to spend their leisure time to help you. So, as already hinted to in your Debian User Forum thread, please try to describe your problem succinctly and clearly, in a way that makes it easy for people to help.
Between your Debian thread and this one, you "hint" at multiple problems/questions, some that might be related to LinuxCNC (RT kernel installs and logfiles filling up your harddrive), and some that certainly aren't (network and desktop applications in general).
This forum might be able to help you with the LinuxCNC-related stuff. After reading through your Debian thread and your original post, my *guess* is you actually want help finding out why your harddisk is filling up. Is that correct? If so, did you follow the advice from the Debian thread to look into your logs? What's the result? What kind of messages are filling them up?
The following user(s) said Thank You: TglEMC
21 Aug 2022 23:48 #250176
by TglEMC
Replied by TglEMC on topic Support structure and upgrades
Thank you for your reply. I do have a plan to look at the problem in depth now that I know what the problem is. The biggest question in my mind right now is should I have started this thread here, or was Debian support the right place for this.
I will have to run the install again to re-create the problem. Not hard to do. Now that I know what to look for I can catch it before it crashes the system.
I still do not know who manages the updates and upgrades. Is that Debian OS, or LinuxCNC?
At this point, I will continue with the Debian thread for this problem.
22 Aug 2022 00:02 #250178
Replied by rodw on topic Support structure and upgrades
The only linuxcnc package in the Debian repositories is found in Debian Bookworm (Debian 12) and Sid (Debian Unstable).
ref: packages.debian.org/search?keywords=linu...uite=all§ion=all
This is a snapshot of Debian master taken from time to time.
It will not work on Buster due to python version changes and a lot more.
So yes, Debian are not involved at all in Buster.
If you find a bug, you can report it here
github.com/LinuxCNC/linuxcnc/issues
If you fork the linuxcnc repo and fix a bug, you can create a pull request on git hub for consideration by the dev team.
In my view Linuxcnc is quite different to most open source projects as there is no sponsor or commercial body of work to fund any development. Its all 100% volunteers!
- Thank you received: 5946
22 Aug 2022 09:30 #250191
Replied by tommylight on topic Support structure and upgrades
I have Debian Bookworm on an Acer laptop that will start using all resources after some days of only playing music, usually 3 to 5 days, and the only remedy remains the power button.
Did not have time to check what is going on as the terminal does not work when it gets to that stage.
This same laptop was on and in use for nearly 2 years with Linux Mint 19.
Now i left a terminal open running Top to see if i can find out what is causing such behaviour.
It never runs LinuxCNC although it is installed, so using RT kernel.
24 Aug 2022 23:43 #250359
by TglEMC
Tommy, sounds like you need to upgrade! LOL
Thanks for all the information you have provided guys. I have asked the Debian guys to close that thread. Not sure I will be trying that again.
My stretch install is running, and I will be leaving at the long from now on.
I will move to Buster at some point in the future, but it does not run well on my old machine yet.
25 Aug 2022 00:05 #250362
Installed Linux Mint 21 yesterday, i hate needing to turn the volume up while the music is playing and nothing happening.
I did !Tommy, sounds like you need to upgrade! LOL
Time to create page: 0.131 seconds
