lsusb doesn't show anything
- Routerworks
- Thank you received: 8
22 Aug 2022 13:50 #250203
by Routerworks
lsusb doesn't show anything was created by Routerworks
When I use lsusb to find out if my usb wifi is plugged in it doesn't show anything.
I know all my usb ports work because I have used them keyboard, mouse etc. When I plug in a usb drive it automatically shows up on the desktop without any problems.
Don't know where to go with this.
- Thank you received: 6006
22 Aug 2022 14:42 #250207
Replied by tommylight on topic lsusb doesn't show anything
Some new wifi dongles do not show at all using lsusb, so i do not bother using them due to the stinking suspicion that they are some type of "software emulated" cr@p.
Small black TP-Link ones do not work, white older ones work perfectly well, new ones with a big antenna work but signal is much weaker than the white ones without antenna.
You can try:
sudo lsubs
But i doubt it will help as even if it does show, it will most probably require a lot of messing about to get it to work.
BTW, are you sure the adapter works? Did you try it on Windows?
You can try:
sudo lsubs
- Routerworks
22 Aug 2022 19:20 #250222
by Routerworks
Replied by Routerworks on topic lsusb doesn't show anything
Odd. It does show up with "dmesg" when I plug it in. But nothing shows under lsusb.
[ 33.280022] eth0: no IPv6 routers present
[ 81.184017] eth0: no IPv6 routers present
[ 129.344018] eth0: no IPv6 routers present
[ 177.632013] eth0: no IPv6 routers present
[ 522.832019] eth0: no IPv6 routers present
[ 1221.844025] usb 1-4: new high-speed USB device number 4 using ehci_hcd
[ 1221.977579] usb 1-4: New USB device found, idVendor=2357, idProduct=011f
[ 1221.977583] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1221.977587] usb 1-4: Product: 802.11ac WLAN Adapter
[ 1221.977590] usb 1-4: Manufacturer: Realtek
[ 1221.977592] usb 1-4: SerialNumber: 00e04c000001
Not so concerned with TP-Link wifi as I plan to get rid of it, not worth the bother.
Just using this as a learning experience with installing and uninstalling packages and being able to check ports.
Time to create page: 0.146 seconds
