Prefered hardware for LCNC
11 Sep 2022 13:24 #251677
by Temo
Prefered hardware for LCNC was created by Temo
Hello
So I want to set up LCNC for running a Onefinity router but have several options for hardware:
RPi 4, with 4 GB mem
Older Thinkpad W510 laptop running WIN 7
Older stationary tower pc running WIN 7, self build more than 10 years old
Newer small form factor pc running WIN 10, self build 3 years old
Newer Thinkpad P50 running win 10
With all options I was thinking of running Mesa 7i76e or 7c80/81
I would prefer the RPi 4 if it’s now been proven a stable build, 32 or 64 version
What is the current recommendationsÂ
Terje
Terje
- Thank you received: 5948
14 Sep 2022 23:34 #251953
Replied by tommylight on topic Prefered hardware for LCNC
Besides laptops, all of those have a good chance of running LinuxCNC, so download the official ISO, burn it to a USB stick, boot those PC's from it.
Choose live mode, everything will work as normal but it will not touch the existing stuff on the hard drive.
15 Sep 2022 18:40 #252021
by Temo
Replied by Temo on topic Prefered hardware for LCNC
Thank you
If I understand you correct, this means running LinuxCNC from a usb-stick or an external usb hard drive. Will it be as responsive as running it from an internal hard drive, installed in a regular manner?
Terje
Terje
15 Sep 2022 18:48 #252022
Depends on the speed of USB, USB stick or hard drive, but it is very usable.
USB3 with a USB SSD will be pretty much the same.
15 Sep 2022 18:59 #252025
by Temo
Thanks again
I did buy a usb ssd to use with the RPI some time ago on another prosjekt, du you think the RPI4 will work for this, it had been fun then?
15 Sep 2022 19:18 #252027
No idea, don't have a RPI4, nor do i plan to get one at current prices.
15 Sep 2022 19:21 #252029
by Temo
Ok, thank you
19 Sep 2022 15:51 #252349
by Temo
So i've decided to try out the RPi4 path, but I'm relative new to Linux and new to LinuxCNC.
I will run an Onefinity Machinist version router with dual y-axis motors with a Sorotec router that have a 0-10V interface for speed control, one tool setter, one touch probe, one wireless pendant and a Gecko G540 4 in 1 stepper driver: www.onefinitycnc.com/product-page/onefinity-machinist-original
www.onefinitycnc.com/product-page/onefinity-3-axis-touch-probe
www.sorotec.de/shop/Sorotec-SFM-1000-PV-ER.html
www.sorotec.de/shop/Tool-Length-Sensor-Sorotec-Small-8mm.html
www.geckodrive.com/products/g540-4-axis-digital-stepper-drive
I've looked at two breakout boards for the RPi 4, the Mesa 7c81 and the 7i76e. I see there are a huge difference in price, where the 7c81 is 90$ and the 7i76e is 200$. The 7c81 also have a much smaller form factor as it integrate with the RPi4.
So my question as a noob in this area, what board will be the easiest for me to set up and work with my accessories/drivers, and are there any known good step by step tutorials for this or any special threads in here I should read for that matter?
Terje
Terje
- jay.perez1
- Thank you received: 3
10 Dec 2022 22:26 #259145
by jay.perez1
Replied by jay.perez1 on topic Prefered hardware for LCNC
Hi Temo,
Did you make a decision on which Mesa board you're going to use ?
Looks like the main difference between the two is that the 7c81 requires additional breakout boards connected via the three 26 pin ports in order to connect anything to it.
The 7i76 has the connections built-in on the board.
Jay
Jay
Time to create page: 0.710 seconds
