System latency search
24 Sep 2022 13:53 #252659
by MeisamVS
System latency search was created by MeisamVS
AMD FX(tm)-6100 Six-Core Processor
CPU max MHz: 3300,0000
Mem: 12'003'464
2.8.4 on new ISO installed on new 128Gb SSD
Linux 4.19.0-21-rt-amd64 x86_64
And yet:
Servo thread 435830
Base thread 238313
How do I identify the source of my problems?
Mem: 12'003'464
And yet:
Servo thread 435830
Base thread 238313
24 Sep 2022 14:05 #252661
by MeisamVS
Replied by MeisamVS on topic System latency search
While writing the previous post, already 2979037 and 258006 respectively.
- Thank you received: 5946
24 Sep 2022 14:52 #252663
Replied by tommylight on topic System latency search
Open a terminal and type:
uname -a
What does it say?
In the BIOS disable everything with power saving, C states, hyperthreading, turbo, speed step, serial, modem, agresive pci-e power management, etc. Save and reboot.
uname -a
What does it say?
24 Sep 2022 21:32 - 24 Sep 2022 22:04 #252688
by MeisamVS
uname -a
Linux INVENTOR 4.19.0-21-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.249-2 (2022-06-30) x86_64 GNU/Linux
If ACPI Function is set to [Disabled], the computer hangs at the "Loading initial ramdisk..." loading stage. What should I fix?
Last edit: 24 Sep 2022 22:04 by MeisamVS.
25 Sep 2022 00:00 #252690
ACPI should be left enabled.
25 Sep 2022 14:03 #252712
by MeisamVS
The thing is that the problems with the delay started after some update, maybe from 2.7 to 2.8 or something like that. Before that everything was fine, on the same BIOS settings, on the same computer.
Until recently, I didn't pay attention to the messages about the delay at startup and worked quietly. But now the machine has a frequency converter and I can't set the PWM. When I change the spindle speed, the pulse rate does not change. Maybe the delay is the reason for that?
- Thank you received: 1370
26 Sep 2022 15:54 #252780
Replied by Todd Zuercher on topic System latency search
If you updated from an older 2.7 version using a RTAI kernel to an newer version of 2.8 and a Preempt-RT kernel. That is a big change and a lot of hardware that works well with one may not work very well with the other. You may need to look into switching back to an RTAI verion (if that is what you had before.)
26 Sep 2022 17:48 #252792
by MeisamVS
Yes, I've already thought about it. In that case, do I have to reinstall the system again or can I somehow roll back to the previous version?
28 Sep 2022 12:34 #252932
If you installed the newer Linux version beside the old one instead of overwriting it, then yes, but that is very unlikely, unless you purposely chose to do that when installing the new OS.
You should at least be able to make backup copies (or have them already) of your machine's configuration files. Saving them back to the new "old" Linuxcnc installation should at least save you from having to remake them.
However reinstalling older obsolete versions of Linux can be an arduous task because the old Linux (Debian or Ubuntu) repositories for them are no longer available on the internet. So installing or updating any programs other than are included on your installation media can be difficult or impossible.
Time to create page: 0.175 seconds
