Debian 13 update broke PyQt5
01 Oct 2022 12:05 #253167
by JT
Debian 13 update broke PyQt5 was created by JT
I just did an update on my Debian 13 dev PC and PyQt5 was removed and can't be installed. Kinda hard to test mesact without PyQt5... anyone have any ideas?
I'm using Debian 13 only because it's the only kernel that works correctly with my video card.
JT
john@cave:~$ sudo apt install python3-pyqt5
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python3-pyqt5 : Depends: qtbase-abi-5-15-4 but it is not installable
E: Unable to correct problems, you have held broken packages.
JT
01 Oct 2022 12:10 #253168
by JT
Replied by JT on topic Debian 13 update broke PyQt5
I tried aptitude as well...
JT
john@cave:~$ sudo aptitude install python3-pyqt5
The following NEW packages will be installed:
python3-pyqt5{b} python3-pyqt5.sip{a}
0 packages upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,546 kB of archives. After unpacking 17.1 MB will be used.
python3-pyqt5 : Depends: qtbase-abi-5-15-4 which is a virtual package and is not provided by any available package
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) python3-pyqt5 [Not Installed]
JT
01 Oct 2022 16:19 #253187
by JT
I got a reply from #pyqt
Just my luck I guess...
JT
<mitya57> JT-Cave: we are in the middle of transition, it will be sorted out in a few days.
JT
Time to create page: 0.167 seconds
