- Hardware & Machines
- Computers and OS's
- Copy paste between Windows and LinuxCNC on Virtual Box [SOLVED]
- xlordofpainx
- Thank you received: 5
19 Oct 2022 10:58 - 20 Oct 2022 14:57 #254507
by xlordofpainx
So I am using a virtual box to run the iso image provided with Linux CNC. Normally you can copy and paste between these when you enable the Biderctional option in the Virtual box. But this is not working with the Linux CNC Iso. Is anyone else with this problem?
[SOLVED] by installing VB guest additions
Last edit: 20 Oct 2022 14:57 by xlordofpainx.
- Thank you received: 5946
19 Oct 2022 13:06 #254519
Replied by tommylight on topic Copy paste between Windows and LinuxCNC on Virtual Box
Moved to "computers and OS's"
20 Oct 2022 02:03 #254582
by spumco
Replied by spumco on topic Copy paste between Windows and LinuxCNC on Virtual Box
Just tried - not working for me, using VM with MX21. Drag and drop doesn't work, neither does ctl-c, ctl-v for text.
Wonder if having shared folders turned on in VM causes a problem with copy-paste?
- xlordofpainx
20 Oct 2022 14:50 #254601
by xlordofpainx
Replied by xlordofpainx on topic Copy paste between Windows and LinuxCNC on Virtual Box
Hey. We fixed it. First of all you have to install guest additions after doing that you can copy paste and resize and stuff. Now In my case I was not able to resize:
Here is a list of all tutorials on the topic. It was kinda hard getting the guest additions to work on the Debian Linux CNC iso:
www.reddit.com/r/virtualbox/comments/c2x...boxclient_failed_to/
askubuntu.com/questions/810980/unable-to...ons-on-lubuntu-16-04
www.virtualbox.org/manual/ch04.html#additions-linux
forums.virtualbox.org/viewtopic.php?t=86281
forums.virtualbox.org/viewtopic.php?f=2&t=98868
www.linuxbabe.com/debian/install-virtual...ons-debian-9-stretch
Eitherway I am not using VB anymore as i cant connect to my mesa card when using virtual box. Cheers
Time to create page: 0.167 seconds
