Parallel port control pins less than 1V(output)
- TooTall18T
- Topic Author
- Thank you received: 13
04 Nov 2022 13:33 #255911
by TooTall18T
Parallel port control pins less than 1V(output) was created by TooTall18T
Hi, I'm not sure if this is the right place for my topic. If not feel free to move it.
At the moment I'm using a Longshine PCIe two port parallel port card at my milling machine. ( www.reichelt.de/2-port-parallel-pcie-kar...tct=pos_3&nbc=1&&r=1 )
Until now I didn't use the control pins 1, 14, 16 and 17 , but now I try to get them to work as outputs.
Both parallel ports are configured as "out" (loadrt hal_parport cfg="0 out 1 out") and all pins can be used correctly but not the four control pins.
If I use them as output I can toggle them in LinuxCNC but the voltage is less than 1V . As high signal. Every time I start the computer again I get a other voltage sometimes 0,235V, sometimes 0,755V or something in between. The other outputs have 3,3V .
I also tried not to use "parport_pc" and removed it with "sudo rmmod parport_pc" and use "loadrt hal_parport cfg="0x3008 out 0x3018 out" " instead. I only got a message in LinuxCNC "No parport registered at 0x3018. This is not always an error. Continuing.", but the card can be used like the way before.
With the ptest.hal/.xml I can not toggle the control pins. They stay at 0V .
I have tried to set the parallel port to a other mode by using modprobe (spp, ecp, epp), but I can't see any changes. Is anywhere a file or a program output where I can see the actual setting of the mode?
If I change the settings in hal to "in" or "x" I can see that all pins change there function how it should be, but the control pins have still less than 1V .
Today I could test the card on Windows XP and Mach3 .
The control outputs have 1,6V that is more than on Linux but still not enough to switch the Schmidt-Trigger. And on Windows the input pins have a pull up resistor(2,4V) but not at Linux.
During my search for solutions, I saw that I'm not the only one using a card with the chipset.
I'm working at this problem some days and now I'm out of ideas.
Maybe I did something wrong and someone here can see it.
sudo lspci -vv
sudo dmesg |grep parp
cnc-para.hal
Linux linuxcnc 4.19.0-22-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.260-1 (2022-09-29) x86_64 GNU/Linux
sudo lspci -vv
11:00.0 Parallel controller: MosChip Semiconductor Technology Ltd. PCI 9865 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 16
Region 0: I/O ports at 3008 [size=8]
Region 1: I/O ports at 3000 [size=8]
Region 2: Memory at dc101000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at dc100000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [48] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot-,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Kernel driver in use: parport_pc
Kernel modules: parport_pc
11:00.2 Parallel controller: MosChip Semiconductor Technology Ltd. PCI 9865 Multi-I/O Controller (prog-if 03 [IEEE1284])
Interrupt: pin C routed to IRQ 18
Region 0: I/O ports at 3018 [size=8]
Region 1: I/O ports at 3010 [size=8]
Region 2: Memory at dc103000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at dc102000 (32-bit, non-prefetchable) [size=4K]
[ 14.304480] parport0: PC-style at 0x3008, irq 16 [PCSPP,TRISTATE,EPP]
[ 14.399507] parport1: PC-style at 0x3018, irq 18 [PCSPP,TRISTATE,EPP]
cnc-para.hal
# Generated by stepconf 1.1 at Mon Apr 12 17:09:52 2021
# Änderungen an dieser Datei werden beim nächsten
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
###loadrt hal_parport cfg="0x3008 out 0x3018 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
##1# loadrt or2
##1# addf or2.0 servo-thread
addf parport.1.read base-thread
addf parport.1.write base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-cw <= spindle.0.forward
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
net probe-in => motion.probe-input
##1# net probe-in motion.probe-input <= or2.0.out
net xdir => parport.0.pin-02-out
net xstep => parport.0.pin-03-out
setp parport.0.pin-03-out-reset 1
setp parport.0.pin-04-out-invert 1
net ydir => parport.0.pin-04-out
net ystep => parport.0.pin-05-out
setp parport.0.pin-05-out-reset 1
setp parport.0.pin-06-out-invert 1
net zdir => parport.0.pin-06-out
net zstep => parport.0.pin-07-out
setp parport.0.pin-07-out-reset 1
net coolant-flood => parport.1.pin-02-out
net coolant-flood => parport.1.pin-01-out
net coolant-flood => parport.0.pin-01-out
##net coolant-flood => parport.1.pin-14-out
##net coolant-flood => parport.1.pin-16-out
##net coolant-flood => parport.1.pin-17-out
net spindle-cw => parport.1.pin-03-out
net home-x <= parport.0.pin-10-in
net home-y <= parport.0.pin-11-in-not
net home-z <= parport.0.pin-12-in-not
##1# net touchprobe-in or2.0.in0 <= parport.1.pin-10-in-not
##1# net toolprobe-in or2.0.in1 <= parport.1.pin-12-in-not
##2# net probe-in <= parport.1.pin-12-in-not
net estop-ext <= parport.1.pin-13-in-not
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 70000
setp stepgen.0.dirsetup 70000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net home-x => joint.0.home-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 70000
setp stepgen.1.dirsetup 70000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net home-y => joint.1.home-sw-in
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 70000
setp stepgen.2.dirsetup 70000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable joint.2.amp-enable-out => stepgen.2.enable
net home-z => joint.2.home-sw-in
net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
- Thank you received: 5951
04 Nov 2022 15:55 #255928
Replied by tommylight on topic Parallel port control pins less than 1V(output)
Did you measure with or without load?
Usually on my cards, those pins require more current as inputs, as outputs i had no issues ever, except the voltage is always a bit lower than other 8 outputs, 3.1 to 3.2V for a 3.3V board, and 4.3 to 4.5V for a 5V board.
- TooTall18T
- Topic Author
04 Nov 2022 19:08 #255939
by TooTall18T
Replied by TooTall18T on topic Parallel port control pins less than 1V(output)
I measured it directly at the port, at the other end of the cable, with 10k pull down resistor, without the resistor and with and without the Schmit-Trigger. The voltage stays the same unless I restart the computer.
05 Nov 2022 22:43 #256037
Replied by andypugh on topic Parallel port control pins less than 1V(output)
Try wiring them as sinking outputs. I suspect that you can safely pull them up to 5V (because it is meant to be a parallel port, after all) and you can generally rely on a parport to sink 15mA.
I wouldn't rely in that in this case, but a pull-up sized for sinking 5mA will probably work.
The following user(s) said Thank You: TooTall18T
- TooTall18T
- Topic Author
06 Nov 2022 10:57 #256055
by TooTall18T
Thanks andypugh it works.
Because of the 3,3V output signals I am using 3,3V on the pc side of the board.
With a 680Ohm pull up resistor a current of approx 4mA flows through the pin of the parallel port. I can measure a voltage between 0,52V and 2,9V.
I also tested it with a 1k resistor. The current is approx 3mA and the voltage switches between 0,2V and 2,8V.
In my case the parallel port triggers a Schmitt-Trigger and the 0,2V and 2,8V are clean logic levels at 3,3V supply voltage.
In my case the 10k resistor that I used as pull down before is to large as a pull up and that is the reason why it didn't work when I tested it.
The following user(s) said Thank You: joekline9
Time to create page: 0.180 seconds
