- Hardware & Machines
- Computers and OS's
- RTAI 5.3.3 Delta release for LinuxCNC (kernel 5.4 debs available)
19 Nov 2022 21:03 #257123
by Bari
RTAI kernel 5.4 Debian packages are up!
github.com/NTULINUX/RTAI/releases/tag/v5.3.3-delta
If these check out OK, they will be marked as stable.
- Thank you received: 5949
22 Nov 2022 19:50 #257366
Replied by tommylight on topic RTAI 5.3.3 Delta release for LinuxCNC (kernel 5.4 debs available)
Sorry for not having time to test.
29 Nov 2022 20:37 #258022
by DomCa
Replied by DomCa on topic RTAI 5.3.3 Delta release for LinuxCNC (kernel 5.4 debs available)
Dear Bari,
I currently have a LinuxCNC2.8 RTAI setup from 2 years ago and would like to test 2.9 with RTAI. I want to use RTAI because it gives me the best latency on my PC and I use the Parport for stepper signal generation.
Is there a tutorial/documentation on how to install a LinuxCNC 2.9 from scratch and then add your RTAI kernel?
Thanks!
Dom
Thanks!
Dom
29 Nov 2022 21:14 - 30 Nov 2022 18:01 #258025
by NTULINUX
Hi Dom,
So there are no LinuxCNC packages built right now against my latest RTAI 5.3.3 Delta release yet, to my knowledge. Building LinuxCNC though once you have RTAI installed is very easy.
For simplicity sake, let's stick with just the 5.4 kernel packages.
Download the RTAI 5.4 kernel debian packages:
You need linux-image, linux-headers and rtai-modules:
github.com/NTULINUX/RTAI/releases/downlo...ai-amd64-1_amd64.deb
github.com/NTULINUX/RTAI/releases/downlo...xcnc-delta_amd64.deb
Once you have those downloaded, in command line:
Specify the full path to the Debian packages after the `-i` if you are not currently in the directory of the .deb files.
After that, build LinuxCNC master branch from source:
You should now be able to launch LinuxCNC, latency-test and latency-histogram via the following commands:
The build dependencies for LinuxCNC must be installed before running the above `./configure` command.
Refer to this page for more info:
linuxcnc.org/docs/master/html/code/build...g-Build-Dependencies
To match that documentation page, you can use this `git clone` command instead of the one I listed above:
Replied by NTULINUX on topic RTAI 5.3.3 Delta release for LinuxCNC (kernel 5.4 debs available)
Dear Bari,
Thanks!
Dom
Hi Dom,
sudo dpkg -i linux-image-5.4.224-rtai-amd64_5.4.224-rtai-amd64-1_amd64.deb
sudo dpkg -i linux-headers-5.4.224-rtai-amd64_5.4.224-rtai-amd64-1_amd64.deb
sudo dpkg -i rtai-modules-5.4.224_5.3.3-linuxcnc-delta_amd64.deb
git clone https://github.com/LinuxCNC/linuxcnc
cd linuxcnc/src
./autogen.sh
./configure --enable-non-distributable=yes
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcnc
latency-test
latency-histogram
git clone https://github.com/LinuxCNC/linuxcnc linuxcnc-dev
Last edit: 30 Nov 2022 18:01 by NTULINUX. Reason: fixes (added rtai-modules)
The following user(s) said Thank You: RobC
29 Nov 2022 21:24 - 30 Nov 2022 02:30 #258026
by NTULINUX
I'm never posting commands on this forum again, you guys have the absolute worst post editor imaginable.
Forgot to mention,
After you install the kernels, reboot into your new RTAI (5.4) kernel before building LinuxCNC. Select the RTAI kernel via the GRUB menu on boot.
Editing this post instead lol.
Forgot to mention,
Last edit: 30 Nov 2022 02:30 by NTULINUX. Reason: More info
01 Dec 2022 08:30 #258193
by DomCa
Hi NTULINUX,
Thanks a lot for your guide! I will give it a try this weekend.
Regards,
Dom
Regards,
Dom
01 Dec 2022 19:55 #258254
by NTULINUX
Awesome! I used Debian Bullseye/11 for my testing, but Bookworm/Testing/12 should also work. The LinuxCNC 2.8 branch does not have the latest RTAI fixes.Hi NTULINUX,
Regards,
Dom
Time to create page: 0.095 seconds
