Digitus DS-30040-2 PCIe parallel card
- cnc_rocket
06 Dec 2022 16:08 #258715
by cnc_rocket
Digitus DS-30040-2 PCIe parallel card was created by cnc_rocket
Hi there
I am currently looking to buy a PCIe parallel card with EPP, but I need some help.
My CNC uses a LPT cable, and I am currently using an old computer with linuxcnc.
But I want to change my setup to a newer computer.
This new computer motherboard has only PCIe slots (the motherboard doesn't have old PCI slots).
So I started looking for PCIe cards.
I was wondering if the Digitus DS-30040-2 would work well with linuxcnc 2.8.
This card uses a MCS9901CV-CC chip.
I found in the linuxcnc wiki that cards that use these chips would work well.
But I also found some forums that say PCIe cards with these chips don’t work well.
www.forum.linuxcnc.org/38-general-linuxc...moschip-ms9901-cv-cc
Does anybody have experience with these cards?
Or do you recommend other cards?
07 Dec 2022 11:20 #258799
by ississ
Replied by ississ on topic Digitus DS-30040-2 PCIe parallel card
I used Sunix PAR4018A (PCI) card with 2 ports with SUN1888 controller.
This one worked also with a PCIE-PCI bridge on a motherboard with only PCIE slots.
Choose a card with a chip that does not need any own driver in any os and it should work.
Another possibility is to switch to mesa 7i92.
08 Dec 2022 23:24 #258932
Replied by andypugh on topic Digitus DS-30040-2 PCIe parallel card
Rather than an actual PCIe parallel port, you could consider a Mesa 6i25. It connects just like a parallel port to the existing controller, but has the advantage that it will definitely be compatible and it will produce far more accurate (and faster) step pulse timing.
It seems that store.mesanet.com and mesaus.com are both out of stock, but eusurplus.com (Portugal) is showing stock.
- cnc_rocket
19 Feb 2023 19:04 #264822
by cnc_rocket
Replied by cnc_rocket on topic Digitus DS-30040-2 PCIe parallel card
A quick update:
I bought the card and every thing works fine.
I only had to enable the PCIe address in my terminal, which I did by following this tutorial.
22 Feb 2023 17:45 #265046
by DrKnow65
Replied by DrKnow65 on topic Digitus DS-30040-2 PCIe parallel card
@cnc_rocket,
I have been troubleshooting a pair of MOSchip 9901 parallel port/rs232 cards that I have been unable to get into EPP mode. It sounds like after enabling your cards you were able to establish EPP? Would you mind doing a " sudo lspci -vv " ( your parallel port card should be one of the last entries in the list) and tell me what mode your card is in after you have booted but before you have run LinuxCNC? For example SPP, ECP, EPP, or IEEE1284.
Thank you,
Jeff
Thank you,
Jeff
Time to create page: 0.101 seconds
