Mini PC with Celeron N5095, won't run Xserver
01 Sep 2023 17:37 #279594
by RB211
Mini PC with Celeron N5095, won't run Xserver was created by RB211
The GPU inside of the Celeron N5095 will not work with Xserver, cannot get LinuxCNC to work with the live install. Apparently this chipset is too new for Debian to like. I am going to give Ubuntu Precise a try and see if that works with it.
Has anyone gotten this chipset to work with Debian?
- Thank you received: 5945
01 Sep 2023 18:51 #279601
Replied by tommylight on topic Mini PC with Celeron N5095, won't run Xserver
Debian 12 BookWorm should work, and installing LinuxCNC is as simple as
sudo apt install linuxcnc-uspace
That also installs the kernel required to run it.
Time to create page: 0.242 seconds
