Best ARM SBC to use with LinuxCNC
05 Sep 2023 15:41 #279995
by cakeslob
Replied by cakeslob on topic Best ARM SBC to use with LinuxCNC
There has been work in the driver field working with spidev using other boards.
User Mr.Bubbles has something going with an UP board, which appears to be an x86, over spidev
github.com/mrbubble62/UPBoard-Remora
github.com/scottalford75/Remora/compare/...Board-Remora:upboard
I dont know if this works or not, but 2 parts interest me,
one is x86 using spi,
and second if this can be used as a framework, combined with a board specific c_gpio.c to bring other SBC online with the project
If anyone with rockchip or allwinner sbc wants to tackle make an attempt that would be cool
The following user(s) said Thank You: itsemast
06 Sep 2023 06:31 #280060
by itsemast
Replied by itsemast on topic Best ARM SBC to use with LinuxCNC
Thank you for this info! This is definitely interesting to me. I will try to adapt it to use SPI in a more standard way, so it's possible to use the same code on any hardware (and if it's not, then unify the interface at least).
The following user(s) said Thank You: cakeslob
30 Sep 2023 21:39 #281956
by GeramyL
Replied by GeramyL on topic Best ARM SBC to use with LinuxCNC
Remora works with Ethernet on the ec500 or any board you could port it to. It’s not required to use remora on a RPi. Because Remora-nv supports Ethernet mode. It has for a while. I am also curious which SBC has the lowest latency because I believe that matters also a little bit. I have been looking at the Industrial Beagle Board as it has a 1.4ghz quad core and another processor also. The question for me is what’s the latency on the Ethernet adapter and on the cores when running latency tests on LinuxCNC. Also it has PRU and Edma which could be used to drive steppers directly from LinuxCNC. I would be willing to make a driver if it performed well as far as latency/jitter goes.
