Getting the touchscreen to work
21 Jan 2024 23:25 #291290
by KpAtch3s
Getting the touchscreen to work was created by KpAtch3s
So on a fresh install of linuxcnc 2.9 touchscreen works out of the box, but when doing an install of debian 12.4 with xfce I can't get it to work. Is there something from the linuxcnc distribution that I can add to my debian 12 install to make it work? Don't need anything fancing, just single point and click would be fine for probe basic.
22 Jan 2024 18:01 #291352
by Unlogic
Replied by Unlogic on topic Getting the touchscreen to work
What type of screen are you using?
22 Jan 2024 19:37 #291361
by KpAtch3s
Replied by KpAtch3s on topic Getting the touchscreen to work
www.amazon.com/gp/product/B09MVN2CBY/ref..._title?ie=UTF8&psc=1
Not really sure what's going on any longer. I decided to go back to the 2.9 linuxcnc install because from a debian12.4 install it wouldn't open my config file, figured at least the touch screen would work. Then I got curious and tried to install probe basic from linuxcnc 2.9 install on my vm box, even though the docs say you should start from debian, and the probe basic install worked. So fresh install of linuxcnc 2.9, but the touch screen isn't working now.
Just tried to install xinput, but that's failing from both terminal and synaptic. About to give up, lol.
22 Jan 2024 22:12 #291372
by KpAtch3s
At this point this should be moved to computer/os.
Just moved the computer from the office to the garage with the machine and the touch screen started working on its own.
- Thank you received: 5934
23 Jan 2024 06:54 #291393
Replied by tommylight on topic Getting the touchscreen to work
Moved.
Thank you.
Thank you.
Time to create page: 0.092 seconds
