PCIE parallel port
- robertjenkins
03 Feb 2024 15:13 #292312
by robertjenkins
PCIE parallel port was created by robertjenkins
My old PC with a parallel port died, as they always do. So I got a new second hand machine without a parallel port, and thought it would be easy to add a PCIE card. Naively I assumed that linux would recognise it automatically, but of course it doesn't. So digging a little in the forum I found various bits of advice, which start with running the lspci command. I did that, and the result is attached. As far as I can see there is no reference there to a parallel port. Any suggestions? (warning - I know almost nothing about linux: I only use it because I'm used to linuxcnc)
- Thank you received: 5934
03 Feb 2024 15:33 #292313
Replied by tommylight on topic PCIE parallel port
If possible, try a different port, you can safely insert it into the graphic card slot if its not busy.
- robertjenkins
03 Feb 2024 16:08 #292315
by robertjenkins
Replied by robertjenkins on topic PCIE parallel port
Thanks. I've tried it in all four slots (including the graphics card slot) with no difference.
However, I see that on the board there is a sticker pointing me to a website for a driver download. There, there is a linux kernel driver, which I have downloaded. The file is called AX99100_SP_PP_SPI_Linux_Driver_v1.9.0_Source.tar
Might this be what I need? If so, what should I do with it please?
03 Feb 2024 17:36 #292319
by JT
Replied by JT on topic PCIE parallel port
Run lspci twice, once with the card plugged in and once without to see if you see an additional card when it's pugged in.
JT
JT
03 Feb 2024 17:49 #292320
Replied by PCW on topic PCIE parallel port
Yes, LinuxCNC does not need a Linux driver for the card,
if the card has standard parallel port hardware.
LinuxCNC just needs the cards address (which lspci should show)
- robertjenkins
04 Feb 2024 11:49 #292369
by robertjenkins
Thanks - have tried that, there is no difference in the lspci output with or without the card
- robertjenkins
04 Feb 2024 15:08 #292405
by robertjenkins
I did manage to extract the driver file, just in case this was the issue. What I get is a single text file which contains a c program. I have no idea what to do with this, so I'm no further forward.
Maybe the card is a dud?
Time to create page: 0.069 seconds
