How Do I Completely Remove XFCE After Installing MATE
- my1987toyota
- Topic Author
- Thank you received: 271
07 Feb 2024 23:36 - 07 Feb 2024 23:58 #292798
by my1987toyota
Well the title say it all how do I fully remove XFCE from Debian after installing MATE?
I have tried the following commands in terminal.
sudo apt remove xfce4
sudo apt remove xfce4-session
sudo apt autoremove
these have mostly worked but I still have some lingering desktop icons related to XFCE.
I had also tried the below commands afterwards but they didn't remove anything further
sudo aptitude purge xfce-desktop didn't work
sudo apt autoremove 'xfce4' didn't remove anything further
sudo tasksel remove task-xfce-desktop didn't remove anything further
sudo dpkg -P xfce didn't remove anything further
Has anyone removed XFCE after installing a different desktop environment?
Or is the answer just do a fresh install of Debian 12.4 with only Mate selected
and install linuxcnc uspace afterwards?
sudo apt autoremove
Last edit: 07 Feb 2024 23:58 by my1987toyota. Reason: adding info
08 Feb 2024 01:01 #292804
by cornholio
Replied by cornholio on topic How Do I Completely Remove XFCE After Installing MATE
This might help.
mxlinux.org/wiki/xfce/how-to-completely-remove-xfce/
The following user(s) said Thank You: my1987toyota
- Thank you received: 5934
08 Feb 2024 01:23 #292809
Replied by tommylight on topic How Do I Completely Remove XFCE After Installing MATE
Or just download the Debian 12.4 with Mate desktop, there are ISO's for every desktop environment.
08 Feb 2024 02:12 #292813
Replied by rodw on topic How Do I Completely Remove XFCE After Installing MATE
Are you sure that the lingering icons belong to xfce and not ones you put on there?
I didn't think XFCE put stuff on the desktop.
- my1987toyota
- Topic Author
08 Feb 2024 11:24 - 08 Feb 2024 11:26 #292838
by my1987toyota
Replied by my1987toyota on topic How Do I Completely Remove XFCE After Installing MATE
I should clarify. It leaves XFCE terminal and a few others in the menus. When I get done at work I will write down the exact ones I can find
and where they are located. That said if the work around is as tommylight has said install the Mate iso and install linuxcnc from there so be it.
On the plus side it bypasses the current problem (as of 2-8-2024) of the raspi-firmware inadvertently being installed as well.
Last edit: 08 Feb 2024 11:26 by my1987toyota. Reason: adding information
08 Feb 2024 12:12 #292843
Some stuff can not be removed as they are dependent on other stuff that is in use by the Mate DE, this is inherent to Linux and the way dependencies are checked. Removing some left overs would also renove dependencies that are still required by other packages still in use.
Leaving them has no adverse effects and can be used, despite being named for the DE that has been removed.
Time to create page: 0.175 seconds
